The smallest available connectorized bandpass filter centred on 915MHz. PCB is only 10mm by 12mm by 1.4mm including the fitted rf connectors
Connect link to Tindie to see full technical details of this rf bandpass filter
JPEG Image - 3.85 kB - 06/23/2026 at 15:54
Yes, delete it Cancel
You are about to report the project "915MHz Saw Bandpass Filter Module (+10dBm Max)", please tell us the reason.
