A Pocket-Sized Mini Retro Arcade Machine
Arduboy-compatible mini desktop arcade featuring ATmega32U4, SSD1306 OLED, SPI flash expansion, and sleek 3D printed case.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
### Project Overview
This is a fully functional, palm-sized mini retro arcade machine designed as an interactive desktop art piece. Built upon the open-source Arduboy hardware architecture, this project scales down the classic arcade silhouette into a highly integrated miniature gadget.
### Technical Architecture
* **MCU:** ATmega32U4 running at 16MHz (32KB Flash), fully compatible with the Arduboy library environment.
* **Display:** 1.3-inch Monochrome OLED screen (SSD1306 driver, 128x64 resolution) utilizing SPI communication for high-frame-rate, blur-free retro gaming.
* **Storage Expansion:** Integrated an external W25Q128JVSIQ Flash memory chip (16MB), allowing the device to store and switch between hundreds of 8-bit games simultaneously via a custom bootloader.
* **Controls:** Features a high-quality 5-axis micro-joystick combined with dual responsive micro-switch tactile buttons to recreate authentic retro arcade handling.
* **Power & IO:** Powered by a 500mAh Li。
