Dust-Tolerant Add-On for Extreme Environments
Passive moat geometry + Electrodynamic Dust Shield to protect electrical connectors from contamination.
0 followers
Electrical connector failures from dust contamination are a critical reliability problem in field-deployed autonomous systems: mining robots, defense ground vehicles, outdoor charging infrastructure, and ultimately in space where manual maintenance is not an option.
Dust Troopers is a student-origin team developing a modular dust-mitigation add-on for electrical connectors. The design combines two mechanisms:
• Passive moat geometry: The connector housing is shaped to funnel incoming dust into a capture region away from the electrical contacts.
• Active Electrodynamic Dust Shield (EDS): patterned electrodes on the moat surface drie a multi-phase traveling electric field on disconnect, sweeping captured dust out of the capture zone.
The add-on is designed to retrofit onto existing connectors without requiring redesign. The concept originated from the NASA L’SPACE NPWEE program.
LetterofEncouragement_NPWEE_NASAGlenn.pdf
Adobe Portable Document Format - 59.85 kB - 06/26/2026 at 00:14
Preview
  • 1 × LHS-1D Lunar Highlands Dust Simulant (300g) (Received as donation from Space Resource Technologies)
