I ran across a cool project, "Poppy", an open source bi-ped robot complete with all manner of 3d print files and instructions. I printed one hand and arm--then knew that Blinky needed this to provide a friendly "wave."
I slid the hand into the arm and fastened them together using 2-56 machine screws.
I attached the arm to a servo horn using 2-56 machine screws and nuts.
I printed a bracket to hold the servo motor and attach to the ultracapacitor frame.
I placed the servo motor in the frame and secured it with 2-56 machine screws and nuts.
I attached the arm to the servo motor using the servo horn screw.
I press fit the bracket onto the back of the ultracapacitor frame. I'll secure it and work out the control electronics and software in a later phase.
Mike Rigsby
