Power on reset and external pull-downs
A project log for DTAP2-ULSR
Universal Latch-based Shift Register. Still not JTAG and fewer pins
yann-guidon-ygdesYann Guidon / YGDES • 3 hours ago•0 Comments
So now, RESET is not a level-triggered signal but a sequence.
The previous scheme was to implement weak pull-ups on SC and SD to force it by default. Convenient, simple and no fuss.
But the last log Direct read / flow-through adds a new wrinkle.
The DTAP has several constraints, such as
A pair of weak pull-ups is still "safe" but its actual effect is unknown. Except that in all cases, if you take most cells in the chain, their values will be the same. Which is a condition that can be easily tested.
