R909-tester PCB is ready, but found a bug during assembly!
A project log for R909-Tester: A Modular RP2040 zero Instrument
R909-Tester is a low-cost workshop instrument platform based on the Raspberry Pi RP2040 zero
nobchanobcha 07/25/2026 at 10:110 Comments
To speed up my experiments and add more features, I decided to design and build a custom PCB. However, during PCB layout, I accidentally flipped the orientation of the I2C pin header for the OLED display and routed it on the wrong side! Fortunately, it doesn't affect debugging at all—I just mounted the display turned around, and it works fine for now.
https://nobcha23.hatenablog.com/entry/2026/07/20/191050
The tester includes a continuity tester, capacitance meter, diode checker, and a frequency counter. Surprisingly, the frequency counter responds up to 50 MHz!
---50MHz displaying
I've uploaded the Gerber files for this PCB to GitHub.
--Link address Gerber sketch:
https://github.com/Nobcha/R909-tester/blob/main/R909-tester_Rev1.0_ERRATA.zip
