Blue Horse PCB Badge
Finalist - PCBWay 12th Anniversary Badge Design Contest
0 followers
This project is a custom-designed interactive PCB badge created to celebrate PCBWay’s 12th Anniversary and the Year of the Horse (2026).
The front side of the PCB features a detailed artistic design created using drilled holes and silkscreen graphics, representing two dynamic horses together with the PCBWay logo. The holes are carefully arranged to allow light to pass through, enhancing the overall visual effect.
The back side contains a fully functional electronic circuit based on addressable RGB LEDs controlled by an ESP32 module. The LEDs illuminate the front design through the micro-holes, creating a striking and dynamic lighting effect.
The lower section of the design highlights PCBWay’s wide range of manufacturing services beyond PCB fabrication, including CNC machining, 3D printing, sheet metal fabrication, and injection molding. These elements are visually integrated into the PCB layout to showcase the versatility and innovation of PCBWay’s capabilities.
  I am thrilled to announce that my project "Blue Horse" has been selected as one of the four international finalists in the PCBWay 12th Anniversary Badge Design Contest! This badge beautifully blends PCB Art, hardware electronics, and embedded systems. Making it to the finals is already a huge milestone.
If you like my design, I would truly appreciate your support in the final voting stage.
How to vote:
  1. Visit the contest page: https://www.pcbway.com/activity/anniversary12th.html?activity=Join02
  2. If the voting section doesn't open automatically, just click the “Join the Fun” button at the bottom.
  3. Scroll down to find Blue Horse by Vittorio Loschiavo and click "Vote Now". (Note: If you don't have a PCBWay account, you can sign up for free in just a few seconds. You will receive a verification code via email to confirm your vote).
You can check out the full technical documentation and schematics here: https://www.pcbway.com/project/shareproject/PCBWay_12th_Anniversary_Electronic_Badge_34e972a6.html
Every single vote counts and brings me closer to the finish line. Thank you so much for your time and support!
#PCBWay #PCBArt #Electronics #KiCad #ESP32 #HardwareDesign #EmbeddedSystems #Maker
View project log
