Overview
Tired of clunky, outdated Pi weather projects built on dead API keys and legacy Python 2 frameworks? This project is a modern, high-fidelity software-rendered Flip Clock and Weather Station built from the ground up for modern hardware and operating systems.
Runs on Linux, Windows and Mac os. Mainly designed for a Raspberry Pi running Pi os Trixie with a 7 inch touch screen and display at 1024x768, however resizing the app is saved for your os.
Instead of building a heavy, resource-hogging web app wrapped in Chromium, this client is written natively in Python 3 and PySide6 (Qt6). It delivers a premium, tactile retro aesthetic with smooth alpha-blended animations and dynamic backgrounds, while operating under an incredibly lean resource footprint.
Key Features
- Native Flip Clock Aesthetic: High-fidelity, smooth software-rendered flip cards without the noise, cost, or mechanical wear of physical split-flap hardware.
- High-Density Weather Canvas: Displays rich real-time data including precise temperature, dynamic wind speed, compass direction, humidity, atmospheric pressure, and UV index.
- Atmospheric Dynamic UI: The entire canvas gradient shifts fluidly in real-time based on the time of day (
is_day) and exact weather code data. - Modern & Keyless: Pulls data seamlessly from the free, open-source Open-Meteo API—no subscription fees or easily deprecated API keys required.
- True Cross-Platform Engine: Because it leverages Qt, the exact same codebase runs natively with hardware acceleration across Linux (including Raspberry Pi OS Trixie/Wayland), macOS, and Windows.
Hardware & Optimization
While designed to run cross-platform, this build is perfectly tailored to rescue a Raspberry Pi 4B combined with an official 7-inch touchscreen (1024x678).
The app features a built-in TOUCH_MODE layout detector. When deployed on compact touch screens, it automatically optimizes the UI scaling—swapping dense desktop controls for generous, finger-friendly targets and launching in a seamless kiosk environment. Because it avoids heavy web-engine wrappers, it runs cool and silent on microcomputers, even showing excellent performance potential for low-spec boards like the Pi Zero 2 W.
diddy
Himanshu Dada
Thomas Ruschival
Emre
