Locked out: talking to a chip nobody talks to
A project log for Oh No, Not Another Microwave Spot Welder
I didn't just rewind the microwave transformer — I kept its control board and rewrote the firmware to run a spot welder.
wicherswichers 2 hours ago0 Comments
The TMP89FM42 has a Serial PROM bootloader mode: pull MODE high at reset and it speaks UART at whatever baud rate you open with. No official programmer needed — in theory.
An Arduino UNO became the programmer (AltSoftSerial for jitter-free timing; regular SoftwareSerial corrupted bytes — 0x63 arriving as 0xE3). Getting the protocol right took longer than the wiring:
That last one mattered, because the original firmware is password protected. The read command requires two magic addresses (where the password length and password string live in flash) — get them wrong and the chip just goes quiet. I scanned dozens of plausible locations. Nothing. Samsung's firmware wasn't coming out.
Fortunately I never wanted it — a chip erase wipes the flash and the security along with it. Blank chip, fully writable, mine now.
The Arduino sketch and a Python driver script now do the whole cycle unattended: enter PROM mode, erase, stream the Intel HEX, verify the checksum, reboot. Protocol notes (including the undocumented behaviors) are in the GitHub repo.
