Print anything, and it appears on your dashboard with enterprise-grade security — no code, no fuss.
This small IoT coprocessor listens to any serial output (USB or UART), uses a tiny onboard AI model to intelligently parse the text, and publishes clean JSON to an IoT dashboard over pre-configured mutual TLS. Just plug it in and keep printing normal human-readable text like you already do.
### Key Features
• Two USB-C inputs + two UART serial inputs
• Built-in ambient light, temperature, and humidity sensors
• Easy plug-in support for SparkFun BME280 (accurate temp/humidity/pressure)
• I2C / SPI expansion for additional sensors
• Automatic MQTT topic detection and JSON formatting
• Full mutual TLS authentication
Perfect for makers who want their microcontroller projects online without the usual networking pain. Also ideal for adding secure cloud connectivity to existing hardware with zero development effort.
