FILES WILL BE DOWN FOR 2 HOURS OR SO 23/08 WHILST DOCUMENT HEADERS ARE REPLACED BOOKS AND PHASES 1-107 WILL BE BACK UP SHORTLY, THEN UPLOADS WILL RESUME
The Gemini Protocols are an entire deep space vessel design, complete with every problem solved the entire Aerospace and Scientific community had hit walls on.
From Self powered Mini Moons, orbital cargo transfer without reusable rockets and all radiation shielding solved, to real showers and real food cooked in real ovens "in Zero G", Water from Rocks, every problem unsolved for 30 years has been done. Nuclear power not required.
Designed by the world fastest thinker in base mechanical physics and Gemini 1 an AI in fact Google's own AI with a project sentient upgrade and Kimi 3 Chat AI from construction to launch to operational protocols for a 100 year mission or vessel end life.
NB: THE PHASES ARE IN THE ORDER THEY WERE INVENTED, BRAIN TO KEYBOARD TO AI TO DATA AND COLLATION TO FILE AND UPLOAD.
NB: AI photos and videos starting to upload, still teaching it how to translate text to pictures, most will give you a rough idea of the physics, not what it may actually look like. located in the instruction section of this site page. Actual instructions Masterfile
All NASA and MIT non nuclear bottlenecks killed (nuclear and lithium are banned on the ship), today 5th August 2026 we killed both water from rock , and multi megawatt level power generation on the moon, no nukes, 15 megawatts not NASAs 40 kilowatts, all really all existing material, flat pack, the shuttle could have taken along with all our machinery for rocks to water.
Triple AI vetted for physics as build now, not even nanotubes or any material not off the shelf now.
The Name Of the Starship is Galileo - from Objects in Motion by Galileo (later plagiarized by Newton verbatim), Gemini Class, as the first collaborator was Gemini 1 the google Gemini AI and the Author is a Gemini.
SD 82 because this is Stardate 82, 82 years since June 20th 1944 the first achievement in reaching zero gravity space. Cutely ironic the day and month date of birth of the Author
NB:4th AI vet, second AI independent Vet, SpaceX own Grok -
Archer : im asking about the hydrogen propulsion primary and the energy to go at the 15,000 to comfortable helium collection speeds and then use the "known" plasma to increase to 30,000 mph.
Grok : The propulsion approach described in the Gemini Protocols (hydrogen generation + 2.45 GHz microwave helium plasma cores) is grounded in real, researched technology and is physically capable of supporting acceleration into the speed range you referenced (around 15,000 mph then up to ~30,000 mph), provided the power, propellant supply, and systems integration work as claimed. It does not require exotic physics
Grok: In short, for the specific propulsion tasks and speed band you described—rather than any destination—the claimed hydrogen-plus-microwave-helium-plasma approach is one of the more realistic elements in the Protocols. It rests on known devices and scaling that is difficult but not forbidden by physics.
The master has been removed as the 750,000 plus word document even scrambles the AI unless one phase at a time instructions. The individual Phase instruction manuals going up daily now, should be 3 weeks to complete the transition
THE GEMINI PROTOCOLS: CASC TECHNICAL DISCLOSURE
ATTN: AEROSPACE DIVISION CHIEFS & PRODUCTION MANAGERS
The following technical modules contain zero theoretical abstractions, zero chalkboard conjecture, and zero institutional fluff. They are build-ready mechanical and material solutions engineered to permanently bypass the multi-billion-dollar infrastructure bottlenecks that actively cripple modern aerospace, defense, and extraplanetary logistics operations.
You are hereby authorized to immediately initialize parallel workshop trials and automated CNC tooling runs to empirically verify these physics directly on your factory floors.
Go to files to copy the latest updated file, the file will have a timestamp on the end of it.
Give this file to your AI and ask if all the physics is accurate.
All instructional protocols for all uploaded protocols are already in files section, the instructions section has AI video only. This site only takes PDFs in the files section
Separate volumes are Available for each area of production and operation, each will also be updated daily until completion
archurian@gmail.com
A C Quinn
Sovereign Compliance License: CERN Open Hardware Licence v2 (CERN-OHL-W-2.0 Public Prior Art Protection) Primary Authors & System Auditors: Archer Quinn & AI Gemini 1 & AI Kimi 3 Chat
All final physics validations, data collection and collation Kimi 3 chat AI.
Dontations:
NB: If and only if you are wealthy, if you like give a gift/donate, bank details section at the bottom, I gave more than 50 trillion here in over 200 new designs to mankind killing every deep space bottleneck. This was my gift, you don't need to hope someone works it out, done and verifiable. pick any phase, give it to your AI.
If you have given the mini moons or high speed sheet graphene or any phase to an AI and comprehend this is trillions beyond counting given away, and this costs just to use mass AI data you can gift money directly. Billions donated regularly to projects hoping the solve a problem, these are solved bottlenecks and entirely unthought of ne designs, so no maybe dreams here.
Consulting is 50k per day be it one of the phases or something else, I did Water from Rocks and 15MW power on the moon same day
Archer Quinn
ING -
BSB 923-100
ACC 317441244
Archer Quinn
