McMurdo PLB DIY Battery replacment
Replacing the battery pack of a McMurdo Personal Locator Beacon can be prohibitively expensive but you can do it yourself
0 followers
McMurdo Personal Locator Beacons are used for emitting a distress call with your location to emergency personnel via satellites. They are frequently used in small airplanes, sailboats, or by backwoods outdoor enthusiasts. There are newer similar devices that have advantages but these units have some distinct advantages. Namely, they do not require a monthly subscription. That coupled with their cheap resale price on secondary markets means cost shouldn’t be a factor in having this extra level of safety. However, there is a gotcha. The batteries for these devices are rated for 5 or 10 years and are proprietary. Instead, the company would prefer to have you return the product to them for battery replacement and testing. Even without the service, the battery module alone, if you can find one, may cost more than $200. There are many cases, maybe most, where this is the prudent course of action. But as a backup, maybe a cheaper alternative is acceptable.
McMurdoEnclosure - TOP.stl
printable top of enclosure
Standard Tesselated Geometry - 2.87 MB - 07/18/2026 at 01:37
Download
McMurdoEnclosure - BOTTOM.stl
printable bottom of the enclosure
Standard Tesselated Geometry - 3.56 MB - 07/18/2026 at 01:37
Download
mcmurdo_battery_terminal_holder.stl
holder for crimped JST connector
Standard Tesselated Geometry - 95.98 kB - 07/18/2026 at 01:37
Download
