Conventional microscope rules don't apply here. Removing the lens improves it. Magnification is controlled by distance, and it's always in focus—no adjustment needed. Organisms smaller than the microscope's optical resolution limit can still be detected, and the display can fill an entire ceiling. None of that should work—yet it does.
Removing the laser's collimating lens lets the laser diode's naturally diverging beam illuminate the specimen directly. Because the beam continues to expand after passing through the specimen, magnification is controlled by the distance between the specimen and the projection surface, eliminating the need for an objective lens, a focusing mechanism, or projection optics. The coherent laser light also produces diffraction halos, making organisms smaller than the microscope's optical resolution surprisingly easy to detect.
A single laser projects an elliptical field of view of the plankton sample onto the ceiling. The dark clumps are algae. The small circles are ciliates, too small to be resolved by the microscope but visible as diffraction halos produced by the coherent laser light.
Multiple lasers mounted in rotating cylindrical Laser Pods project adjacent regions of the microscope slide. Rotating each Laser Pod aligns the projected regions to create a wider display, allowing much more of the ceiling to be covered than a single laser can illuminate.
Four independently adjustable laser projection zones are positioned side by side to create a larger field of view than a single laser can produce.
With the collimating lens removed, the laser beam is elliptical, approximately three times longer than it is wide. To maximize ceiling coverage, install each laser module so the flat sides of its brass heat sink are perpendicular to the beam's major axis. This ensures that every Laser Pod produces the same beam orientation.
Close-up of Laser Module Showing Heat Sink Orientation
Major Axis of Beam Pattern Perpendicular to the Heat Sink
The following measurements characterize the optical performance and mechanical design of the projection microscope.
The major and minor axes of the laser beam were measured as a function of distance. The laser case blocks the beam along the ends of the major axis, creating sharp edges that are easy to measure. The minor axis gradually fades into the background and has no sharp boundary, making its width more subjective to estimate.
The microscope resolves features approximately 44 µm wide, as measured with a USAF 1951 resolution target (Group 3, Element 4). The known target dimensions and a 1.47 m projection distance yielded a magnification of approximately 250×.
A 3D-printed frame supports the glass slide, while a hot-glue moat contains the water sample. The fabrication procedure is described in the Instructions section.
Experience the Plankton Planetarium
The hardware is remarkably simple, yet it opens a window into an invisible world. Everything so far has explained how the Plankton Planetarium works. The videos below show why you would want to build one. A single drop of pond water becomes a living world where microscopic organisms swim, crawl, hunt, feed, and interact across your ceiling.
Plankton from Almaden Lake — Four-Zone Plankton Planetarium
This is the Plankton Planetarium in its natural element. A drop of pond water collected locally from Almaden Lake in San Jose, California is projected across the ceiling, where multiple laser zones create a wide viewing area. Watch as microscopic organisms swim, crawl, and interact at room scale.
Loading a Live Pond
Water Sample
Collecting a good sample is more challenging than it first appears. Many microorganisms congregate around clumps of algae, which provide both food and surfaces to anchor on (think salad bar and stool). Unfortunately, the algae also obscure the projection. This video shows the balance between preserving the miniature ecosystem and reducing the algae that...
TomZ
Florian Festi
helge
Jason Cho
