Optimising What Exactly?
It is not easy to optimise most problems have:
- multiple local optima
- multiple objectives
- objective functions may result in degenerative (useless) solutions
- constraint functions may result in degenerative (useless) solutions
- the need to start with a feasible solution
The process involves mapping out the feasibility areas and then focusing in on the most important objectives that result in the best solution.
Finding an initial feasible solution
Fortunately we can start with DIY Walkers solution (but at half scale):
- Axle: (0.0 mm,0.0 mm)
- Hip: (-48.0 mm,33.0 mm)
- Crank L1: 30.0 mm
- Thigh L2: 60.0 mm
- Idle L3: 40.0 mm
- Shin L4: 70.0 mm
- Knee Angle: 90.0 degrees
Here the foot trace down range is 120 degrees between the green markers and 180 degrees inclusing the green markers:
Note how the foot trace slow down near each left/right extremes, and is very fast when the foot up.
Extending the Flat Bottom Range
The first major objective identified was the need to have a flat bottom (as much as practical):
While this objective has been meet for 120 degree range (suitable for a three leg walker). How ever foot lift has been lost.
A Symmetry Constraint
For symmetry, the difference between each Y point at each horizontal extreme is minimise, using:
- DeltaY = ABS(Yfwd-Ybwd)
- Minimum mid-section upper and lower range of 10.0 mm
Here is the result:
Using this as an initial feasible solution, we can impose a flat bottom:
The final walker parameter are:
- Hip: (-53.1 mm,52.5 mm)
- Crank L1: 30.0 mm
- Thigh L2: 60.0 mm
- Idle L3: 59.3 mm
- Shin L4: 60.0 mm
Reducing the minimum mid-section upper and lower range to 5 mm for the final result:
Note the flat bottom has been optimised for 120 degrees
The same design as imported into a CAD package:
Note the cyan bottom range is for 180 degrees.
This is what I see after my optimiser runs:
Clearly the 4 bar linkage can be used for a three foot (120 degree) walker, but its use would be best for relatively smooth floors as the minimum clearance is about 5.0 mm (for a 94 mm step).
The cyan vertical range (for 180 degrees) is about 3.5 mm, suggesting a two foot (rather than three foot) walker is possible, but perhaps some what bumpy ride.
AlanX
agp.cooper
