Inside-Out Wind Turbine
A 3D-printed wind turbine that hides its blades inside a de Laval-style nozzle, with magnets spinning around fixed coils.
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
An inside-out wind turbine: the magnets spin on the rotor, the coils stay fixed on a central column, and the whole thing lives inside a 3D-printed housing shaped like a de Laval nozzle - wide at the inlet, narrow at the throat, so the air speeds up right where the blades are.
This is a physics demonstrator, not a power plant — output is single-digit milliwatts. But it taught me more about induction, cogging, and rectifier thresholds than any textbook problem set. Full build guide is linked below; the messier parts of the story (a capacitor that turned out to be innocent, a coil-phasing dead end, a real fight with cogging) will show up here as build logs.
