Keeping a Cash-Counting Machine Counting
Bill-counting machines kept going down because of a failing optical encoder sensor.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Bill-counting machines kept going down because of a failing optical encoder sensor. Multiple machines went offline in a very short period of time.
The original board was hard to source. So instead of a one-off repair, we reverse-engineered the simple sensor board, designed a drop-in replacement PCB, 3D-printed a mounting bracket matching the original geometry, and produced a batch of 50 units — enough for the client to keep a spare-parts stock on hand and swap a failed unit in minutes instead of waiting on a discontinued part.
A few things that mattered more than expected:
- The mechanical fit of the 3D-printed bracket had to preserve the encoder's optical alignment.
- Designing for a 50-unit batch.
- Component sourcing matters for this project.
Full write-up with photos: https://github.com/DMC1988/2026719-1
#hardwaredesign #pcbdesign #reverseengineering #kicad #electronics
