This is a tool which runs entirely in-browser, supports mobile devices (Android/Chrome only) and lets you program any radio already supported via Chirp.
The project leverages PyIodide (in-browser python interpreter), WebSerial and WebUSB.
The app can now be installed to an Android or iOS home screen: a web app manifest, a generated 192/512/maskable/apple-touch icon set, and a theme-color status bar, so it launches standalone from the launcher (#52).
Added a 🇬🇧 Query RSGB ETCC API action that turns a GPS fix into a list of nearby UK repeaters, nearest first; unlike the przemienniki.net and RepeaterBook imports it needs no CORS proxy, so it works on deployments where those two are disabled (#47).
Binary .img files whose driver differs only by variant or alias now load: Quansheng_UV-K5_egzumer.img previously failed with Unsupported model because the matcher ignored variant, resolved to the wrong UV-K5 driver, and that wrong-but-resolved match suppressed the all-drivers fallback (#46).
Deploys now run the full test suite and the Python syntax check before uploading, so a failing test leaves the live site up; the asset-retention step, which had been silently doing nothing since the move to codeplug.org, points at the right hostname again (#45).
Asset retention is covered by tests driving the real script against a fake Pages site, so an unreachable host fails the deploy instead of retaining nothing while reporting success (#42).
The channel view now shows its "No channels loaded" notice from first paint instead of only once the Pyodide runtime has finished booting.
Dropped test stubs for DOM elements the page no longer has and pinned the remaining stubs to the selectors web/js/ui/dom.js declares; no user-visible change (#43).
