I have tested all PCB electronics, and everything is forking fine, so I can start to program MCU.
I have working code for my previous lidar - it was based on STM32F100 and TSL1401.
So I take code from that project and ported it to new STM32F030 MCU.
At first step I write testing firmware that capture analog signal from sensor to MCU memory and then transfer it PC by UART.
I write PC utility that draw illumination level of 128 sensor's pixels:
Here is a picture with IR laser that I want to use in final design:
The distance to object (white wall) was near 1.8 m.
The next step is printing laser holder and mounting it at PCB.
