• 1
    Open your Joy 2.
    1, Unplug it from everything.
    2. Remove the four silicone feet from the bottom. Fingers should suffice.
    3. Use a medium-sized Philips head driver to remove the four screws.
    4. Use a small flat-head screwdriver, starting from the center rear, to gently pry free the bottom shell casing. It should come off without breaking any plastic pins.
  • 2
    Unplug everything from the motherboard.
    1. Remove the X, Y, and LED flat flex connectors by pulling them gently out of their sockets.
    2. Unclip the Z-axis connector latch with a fingernail; it should pop up 1mm. Lift it up and gently wiggle the Z-axis flat flex cable until it detaches from the board.
  • 3
    Remove the motherboard.
    1. Unscrew the two metal washered screws and the one plastic self-tapping screw from the board.
    2. Lift up the board, making sure not to damage or pull on any flex cables.
