Spreading energy throughout the day while I am away.
motor_mount.stlmotor mount jig, in case you want to print itStandard Tesselated Geometry - 39.14 kB - 03/29/2017 at 02:07 |
motor_mount_jig.dxfcut file for motor mount sheet metal jigAutoCAD DXF - 4.35 kB - 03/29/2017 at 02:07 |
Finishing up the first pulley
Result, pretty happy with it.
Spending some time learning how to use the lathe better, attempting to make some pulleys...
love using the laser cutter to make jigs! please ignore the surface finish :)
plan on using 'cut your own' urethane drive belts with these pulleys
jig for sheet metal motor mount
