SaturnSQL is a web-based SQL editor built for small data teams who are tired of queries living in random text files and Slack DMs.
You connect your database (PostgreSQL, MySQL, SQL Server and others), and your whole team gets a shared workspace: queries are organized in folders, everyone sees the same up-to-date version, and schema-aware autocomplete plus optional AI assistance help you write SQL faster.
The part people use most is scheduling. Any query can run on a schedule and push its results to Google Sheets or a Slack channel, so recurring reports update themselves instead of someone re-running the same query every Monday morning.
Other bits: role-based access (including a reports-only viewer role), TOTP two-factor auth, scoped API keys, a static egress IP for locked-down databases, and charts for turning results into simple dashboards.
