In this video, I build and test a DIY temperature controller circuit using the KYT84 temperature sensor, LM358, CD4093, MOC3021, and TRIAC. PCB from JLCPCB
This circuit can automatically control the temperature of heating devices such as an electric iron, hot plate, and other AC heaters. The output power can be adjusted from 0 to 100 percent, while the temperature feedback allows the circuit to turn the heater on and off automatically to maintain the desired temperature.
The circuit uses an AC zero-cross detection circuit, temperature sensing, comparator control, and an optocoupler to control the TRIAC.
I also test the circuit with an electric iron and a light bulb to demonstrate how the temperature feedback and power control work in real time.
In the future, I plan to develop this circuit into a heating plate for soldering surface-mount components.
youkito1991
Non-ICE
RoGeorge
I made such a controler for aquariums in 1980 with a PT100 probe ! We sold a lot of them.
