Autonomous Garden Rover
Sub $400 Garden Rover with 3000W grass mower, powerful turret plant watering system, autonomous, AI voice (OPEN SOURCE + BUILD GUIDE).
0 followers
This is an OPEN SOURCE outdoor garden robot that can mow grass and water plants for under $400. It features a powerful 3000 watt C6374 motor for mowing grass with electronic height control, and a large Nema17 turret system for watering at target places that supports a normal garden hose. The rover currently uses a 9 axis IMU + wheel encoders for autonomous function. The brain of this rover is a powerful ESP32-P4, which gives this rover the capability to listen and respond to commands using its built in microphone and speaker.
I spend hours each week gardening and mowing grass. As someone into robotics, I realized I could build a garden rover to automate some of these repetitive chores. This project gave me a reason to learn more about robotics while building something useful for my yard.
Watch the demo video here:
To see the full build instructions, SOURCE CODE, schematics, BILL OF MATERIALS, and SOURCE CAD, view the build instructions:
Github Repo
See the full 134 hour documentation journal here:
https://macondo.hackclub.com/projects/9276
Features
  • Under $400, anyone can build it
  • All four wheels are motorized
  • C6374 Motor offers 3000W+ of power, more than most commercial systems
  • Nema17 planetary motors lift and raise the mower using a rope system.
  • The turret system uses high reduction worm + dual stage planetary drives to shoot water
  • Has a microphone and speaker and can run small ai vision/text recognition models
  • Water flow can be controlled using a seperate esp32 controller
  • Can be controlled from a phone or handheld controller
  • Uses a 9axis imu and encoders on all four wheels for precise autonomous
  • The aluminum chassis bends and acts as a suspension
  • Supports raspberry pi 5 with ROS 2 as brain
  • Supports a custom hand held controller from my previous FPV claw drone project
  • Advanced flexibility for conneting new sensors, cameras, and electronics
  • Water resistant
Future Plans
  • Add cameras and GPS+RTK to the autonomous sensors
  • Use stronger drivetrain motors to support a higher speed and better turning (though it would increase the price to build)
  • Replace garden hose adapter system with a water tank onboard the rover
  • Make a custom PCB that combines all the electronics and sub systems into one board with quick connectors for peripherals (much more expensive though)
Portable Network Graphics (PNG) - 276.77 kB - 08/21/2026 at 02:47
Preview
View project log
View all instructions
