- Just updated the ADC measurement logic so that temperature is measured only about twice per second. That means voltage and current can be measured more frequently. The increase of measurement (V+I) rate is from 140 measurements per second to 220! This is equal to the report rate to computer and hence the maximum log rate in the control program.
- When you have an external series resistance, such as a power resistor, to add some extra watts to the power handling, the windows control program now lets you type in the power resistor rating. The program can then automatically stop the load when the external power resistor rating is exceeded (thank you Jyrki for suggesting this!).
