The "Hire an Arduino Programmer" Moment
This project had a specific pain point: the audio buffer management. When streaming over WiFi, you get jitter. If you don't buffer properly, you get stuttering audio. Our first iteration sounded like a broken robot. We had to implement a ring buffer in the firmware to smooth out the network latency before feeding the I2S DAC.
This is where the skill comes in. If you are planning a similar project, you might be tempted to hire an Arduino programmer to handle the code. Honestly, for a simple blinking LED, any script kiddie will do. But for a project like this—where you are dealing with I2S timing, MQTT state machines, and PWM audio metering—you need an engineer who understands memory constraints and real-time systems.
