A Raspberry Pi can run for months as a media server, Home Assistant host, Pi-hole, Docker server, sensor gateway, or other always-on system. In many of these projects, storage problems develop slowly and are easy to miss until package updates fail, containers stop working, or the system reports No space left on device.
I put together this toolkit as a simple way to answer three questions:
How much space is left?
What is using it?
How can I catch the problem before the filesystem is full?
The tools are standard Linux utilities, so the same workflow works on headless Raspberry Pi systems over SSH as well as desktop installations.
Start with df
The quickest check is:
df -h
The -h option makes the values human-readable.
For the root filesystem only:
df -h /
This gives an immediate view of total capacity, used space, available space, and utilization percentage.
If I only need one quick health check on a Raspberry Pi, this is usually where I start.
Check the Actual Storage Devices
df shows mounted filesystems, but it does not clearly show how the physical drives and partitions are arranged.
For that I use:
lsblk -f
This is especially useful on newer Raspberry Pi setups that may combine:
It shows the device, partition, filesystem type, and mount point in one place.
Find What Is Actually Consuming the Space
Once df shows that a filesystem is filling up, the next question is where the data is.
A quick check of the home directory is:
du -sh ~/*
For a broader look at the root filesystem:
sudo du -h --max-depth=1 / | sort -hr | head -n 15
This usually makes the largest directories obvious.
Common storage consumers on Raspberry Pi systems include:
Use ncdu for Interactive Exploration
For deeper investigation, ncdu is probably the tool I use most often.
Install it with:
sudo apt update
sudo apt install ncdu
Then scan the root filesystem:
sudo ncdu -x /
The -x option keeps the scan on the current filesystem instead of following mounted external drives.
ncdu gives a navigable directory tree sorted by disk usage, which makes it much easier to drill down into large directories than repeatedly running du.
For headless Raspberry Pi systems, it is especially convenient because everything works over SSH.
Check System Logs
System logs can grow quietly when a service repeatedly produces warnings or errors.
To see journal usage:
journalctl --disk-usage
If persistent logging is enabled, I also check /var/log and the journal configuration when log growth looks abnormal.
The important lesson here is not to delete logs immediately. A rapidly growing log file often tells you that a service has another problem that should be fixed first.
Check Docker Separately
Docker deserves its own check because container storage can grow independently of the application data you normally see in your home directory.
Use:
docker system df
This reports disk usage from images, containers, local volumes, and build cache.
Before deleting Docker data, I always verify what is actually unused. Commands such as:
docker system prune
can be useful, but they should not be treated as routine commands without reviewing what will be removed.
Find Large Individual Files
If directories look normal but space is still disappearing, I search for unusually large files:
sudo find / -type f -size +100M -exec ls -lh {} \; 2>/dev/null
That can reveal forgotten backups, logs, downloads, database files, or application data that would otherwise be easy to miss.
Watch Disk Usage During a Heavy Task
For downloads, Docker builds, backups, or large file transfers:
watch -n 5 df -h /
This updates the root filesystem usage every five seconds.
It is a very simple tool, but it is useful when you want to know whether a job is consuming storage faster than expected.
A Simple Maintenance Workflow
The complete workflow I normally follow is:
df ↓
Is storage usage high? ↓
lsblk ↓
Confirm which filesystem/device is affected ↓
du / ncdu ↓
Find the directory consuming space ↓
Check logs / Docker / caches / application data ↓
Clean or fix the actual cause
The main idea is to avoid jumping directly to deleting files.
First identify which filesystem is full, then determine what is using it, and only then decide what should be cleaned.
Optional Disk-Space Alert
For an always-on Raspberry Pi, a simple automatic check is more useful than discovering a full filesystem after something fails.
A minimal shell script can read the root filesystem utilization:
#!/bin/bash
USAGE=$(df / | awk 'NR==2 {gsub("%","",$5); print $5}')
if [ "$USAGE" -gt 85 ]; then    echo "Disk usage warning: ${USAGE}%"
fi
This can later be connected to email, MQTT, a monitoring service, or another notification mechanism.
The threshold is deliberately configurable. I do not treat 85% as a universal failure point; it is simply a useful early-warning value for many systems.
What This Project Is Really For
The commands themselves are simple. The useful part is turning them into a repeatable diagnostic process.
A Raspberry Pi that runs continuously will accumulate data differently depending on what it is doing. A Home Assistant system, Docker host, media server, development machine, and sensor logger will all fail in different ways when storage is neglected.
The goal of this toolkit is therefore not simply to free a few gigabytes.
It is to make storage usage observable enough that a Raspberry Pi project does not fail because the filesystem quietly filled up.
The full guide includes additional cleanup examples, GUI tools, Docker maintenance, SSD/NVMe considerations, automation, and troubleshooting notes.
