AirNet CO2 - Low-Power CO2 Monitoring Device
Low-power, relatively affordable sensing device featuring an ePaper display, designed to monitor CO2 concentration, temperature and humidity
The device is designed for low-power battery operation. It is based on an ultra-low-power STM32U031 microcontroller.
CO2 concentration is measured using the STCC4 sensor from Sensirion, temperature and humidity are provided by the SHT40. The display is a 1.54-inch ePaper (eInk) panel with a 27 mm square active area. A RGB LED indicate CO2 levels at a glance. The device is powered by a standard 14500 Li-ion battery, rechargeable via USB-C using the BQ24074 from TI, with a regulated 3.0 V supply provided by the TPS63900.
  • 1 × STM32U031
  • 1 × STCC4 CO2 sensor
  • 1 × SHT40 temperature/RH sensor
  • 1 × 1.54-inch ePaper display
  • 1 × BQ24074 Charging IC
View all 8 components
