I am working on a compact embedded project that can monitor the condition and behavior of a rechargeable battery while it is being used to power a portable electronic device. The main objective is to build a dedicated battery-monitoring module that can measure voltage, current, estimated remaining capacity, charging and discharging activity, and basic temperature information in real time. Instead of relying only on the battery percentage reported by a conventional operating system, the project is intended to collect actual electrical measurements and use them to estimate how the battery is behaving over repeated charge and discharge cycles. This is particularly useful for DIY electronics projects where a microcontroller, display, sensors, and other peripherals may have changing power requirements throughout the day. I want the monitor to operate as an independent layer between the battery and the main electronics, providing useful information without significantly affecting the available power. The system should also be small enough to eventually fit inside a custom enclosure, making it practical for portable devices, robotics projects, handheld instruments, or experimental power systems.
The hardware is being designed around a low-power microcontroller connected to a voltage-sensing circuit, a current measurement device, and a temperature sensor positioned close to the battery. Because directly measuring battery current can introduce unwanted voltage drop, I am evaluating different sensing approaches and paying particular attention to the resistance and thermal behavior of the measurement path. The voltage measurement circuit also needs appropriate scaling and protection so that the microcontroller's analog input remains within its safe operating range under all expected battery conditions. I am planning to include a small display or status interface that can show the instantaneous voltage, current direction, estimated capacity, and charging state. A few hardware indicators may also be used for situations such as low battery, abnormal temperature, or excessive current consumption. Another design consideration is power consumption by the monitor itself: there is little value in building an accurate battery monitor if the monitoring circuitry consumes enough energy to noticeably shorten the operating time of the device being monitored. For that reason, the controller will spend much of its time in low-power states and wake periodically to perform measurements.
The firmware will calculate more than just a simple battery percentage based on voltage. Battery voltage changes depending on load, temperature, charging state, and battery chemistry, so I am experimenting with combining voltage and current measurements with accumulated charge data to produce a more useful estimate. The controller will periodically sample the electrical measurements and calculate values such as instantaneous power and accumulated energy consumption. During charging, the firmware can identify the change in current direction and maintain separate information about charging and discharging behavior. A configurable sampling interval will allow the same hardware to be tested under different workloads without requiring firmware changes. I also want the firmware to recognize unusual measurement patterns, such as a sudden voltage drop under relatively high current, because this could provide useful information about battery resistance or an overloaded power system. Rather than immediately treating every unusual reading as a fault, the software will maintain short-term measurement history and use several consecutive samples before triggering a warning. This should reduce false alarms caused by temporary load changes.
One of the more challenging parts of the project is estimating battery capacity accurately over time. A nominal battery rating does not necessarily represent the amount of energy that will be available in every real-world situation, and the usable capacity can change as the battery ages. To investigate this, I am planning to record complete charge and discharge cycles and compare the measured current over time with the battery's voltage behavior. The collected data can then be used to build a basic model of the particular battery being tested. Instead of assuming that every battery follows the same discharge curve, the firmware could eventually store calibration parameters for different battery types or individual battery packs. I am also interested in tracking changes across multiple cycles because a gradual reduction in measured capacity may provide an indication that the battery is aging. The purpose is not to create a laboratory-grade battery analyzer, but to make a practical monitoring system that provides substantially more information than a simple voltage threshold. Having actual historical measurements should also make it easier to diagnose why a portable project suddenly has significantly shorter runtime than expected.
Data logging will therefore be an important feature of the final design. Measurements can be stored locally at configurable intervals, including timestamped voltage, current, temperature, calculated power, and estimated state of charge. The storage format will be kept simple so that the resulting files can be opened and analyzed on a normal computer without specialized software. I would like to generate graphs showing battery voltage versus time, current consumption, charging duration, discharge duration, and estimated capacity across multiple cycles. These graphs should make it possible to compare different batteries or different versions of the same electronic project under similar conditions. The monitor should also retain a small diagnostic history containing events such as startup, charging detection, low-voltage warnings, temperature warnings, and unexpected resets. This information could be particularly useful when the device is operated unattended because it would provide evidence of what happened before a shutdown rather than leaving only a final battery reading.
The final stage of the project will focus on calibration, repeatability, and protection. I plan to compare the monitor's voltage and current measurements against external measurement equipment and determine how much error is introduced by the sensing circuitry. Different loads will be tested to see whether the current readings remain stable from low-power idle conditions through higher consumption. I will also intentionally vary the workload while monitoring the battery to determine how quickly the firmware responds to sudden changes in current demand. Temperature testing will be performed separately so that the system can distinguish ordinary operating-temperature changes from conditions that should generate a warning. Once the measurements and firmware behavior are reliable, I want to design a small PCB that combines the sensing circuitry, microcontroller, connectors, and protection components into one board. The broader goal is to create a reusable battery-monitoring platform rather than a device tied to one specific project, allowing the same module to be incorporated into portable electronics, robotics, custom instruments, and other battery-powered builds where understanding real-world power behavior is important.
