TypixDeck is a pocket-sized cyberdeck designed from
scratch -- schematic, PCB layout, firmware, and mechanical shell. Not a
Raspberry Pi bolted into an off-the-shelf case.
## The stack
Three boards connected by FPC, no bulky connectors:
- Core Board -- Raspberry Pi CM4/CM5 on SODIMM, ESP32-S3 co-processor,
USB2514B 4-port hub, TPS61088 boost, INA219 x2 + MAX17048 power telemetry,
M.2 2230 NVMe slot
- Keyboard Board -- STM32F042 running a 6x13 matrix, 1.47" status LCD
(JD9853A), rotary encoder, PWM backlight
- Screen/Audio Board -- SSS1629A5 USB audio codec, APA2068 + PAM8406 amps,
stereo MEMS mics
Main display: 3.2" 1024x768 panel (JD9168S) over DPI, GT911 capacitive
multitouch.
## The interesting part: a discrete RGB DPI bus MUX
The CM and the ESP32-S3 both drive the *same* parallel RGB panel. The ESP32
paints a boot screen before Linux is up, then hands the bus over once the Pi
takes control.
The campaign runs until December 24, 2026. The campaign page has the current configurations, reward pricing, and estimated delivery dates.
TypixDeck combines a Raspberry Pi Compute Module, an ESP32-S3 co-processor, a physical keyboard, and a touchscreen in a CNC aluminum body. The current design has the screen and keyboard together on a fixed front face.
One of the parts I have enjoyed developing most is the shared display: the ESP32-S3 can draw to the panel before Linux is ready, then hand it over to the Raspberry Pi.
If you have questions about the hardware or Linux setup, leave a comment below. I would love to hear what you would build or run on it. Thanks for being part of the project!
