2026-08-16: Board arrives, factory menu boots, and the first NextTang image
A project log for NextTang: ZX Spectrum machines on a Sipeed Tang FPGA console
Open-source port of Spectrum FPGA hardware to the Tang Console 138K. 48K, 128K and 256-colour Spec256 run today; the Next core is the goal.
jon-attreeJon Attree a day ago0 Comments
The Console 138K arrived with a 32001C carrier and a 30354 1 GB SOM. The factory TangCore menu came up from the supplied card, the included controller navigated it, and NESTang and SnesTang switched cores.
Loading my own bitstream over JTAG took a detour: passing the packaged .bin files straight to openFPGALoader left HDMI black, and only the original .fs record boundaries load. The first NextTang image, colour bars and a moving logo at 720p, worked once the PLL matched the values a known-good Console design uses.
A lesson that would repeat: a timing-clean build that programs cleanly and shows nothing is the normal failure mode on this board.
Episode 2: We Got Our First Video Output from the Tang Console
