This are all the wooden and aluminum parts you'll need, minus the mounts that hold wood plates (check out the videos). Please keep in mind that there are no holes. But why Kristjan? Because I'm 99.9999% sure that every motor you'll find has different geometry, every arm is different and it goes on. So in order to make this arm, you'll need to be creative. You can follow my instructions as far as you can, but I can promise you that you'll have to figure things on your own too. But hey! That's all part of experience and that is the most valuable thing in life next to health and knowledge.
