Perfect Paul ][
A DECtalk speech synthesizer card for the Apple II, built on a Raspberry Pi Pico. Named for DECtalk's default voice, [:np].
It speaks plain text, sings in DECtalk's phoneme mode, and holds a conversation. Drive it from BASIC with POKE.
Status: finished. The final revision 2 board has been fabricated, assembled and tested in an Apple II, and everything works. The card announces itself out loud at power-up, and both audio paths — I2S through a MAX98357A and PWM through a PAM8403 — are on the board, selected with a jumper. The Gerbers are published: pcb/gerbers-v2.zip.
Contents
- Watch it
- Talking to it
- How it works
- The card
- Schematic
- Build
- Audio
- Demo programs
- Assembly and first power-up
- Validation status
- Possible future changes
- Historical record
- Licensing
Watch it
Perfect Paul II on real hardware — the latest demo.
Earlier: Perfect Paul II - A New Speech Synthesizer For The Apple II — the card talking, singing Daisy Bell, and running ELIZA.
Talking to it
10 DR = -16192 : REM SLOT 4 20 T$ = "HELLO FROM DECTALK" 30 FOR I = 1 TO LEN(T$): POKE DR,ASC(MID$(T$,I,1)): NEXT I 40 POKE DR,13
That is the entire interface. Bytes written to the card's slot window are queued as text; a carriage return (13) speaks the line. Byte 144 ($90) stops speech already in progress, as does 3 (Ctrl-C). DECtalk inline commands are printable text, so "[:np]HELLO" is sent exactly the same way.
Any slot works
The card decodes no address lines. It relies entirely on /DEVSEL, which the motherboard asserts for whichever slot the card is in, so it works in any slot from 1 to 7 with no jumpers and no firmware change. Only the DR constant in BASIC changes:
| Slot | Address | DR | Slot | Address | DR | |
| 1 | $C090 | -16240 | 5 | $C0D0 | -16176 | |
| 2 | $C0A0 | -16224 | 6 | $C0E0 | -16160 | |
| 3 | $C0B0 | -16208 | 7 | $C0F0 | -16144 | |
| 4 | $C0C0 | -16192 |
The window is $C080 + 16 × slot. A0-A3 are intentionally not decoded, so all 16 addresses in it are mirrors of the same write-only register.
On an Apple II+ note that slot 0 holds the Language Card and slot 6 is almost certainly your Disk II, so 2, 4 or 5 are the practical choices.
How it works
Core 0 receives bytes from an Apple II slot write cycle using RP2040 PIO. Core 1 runs DECtalk synthesis and feeds the audio path. There is no slot ROM, no status register, and no read cycle — the card is write-only, which is what keeps the hardware down to two logic chips.
Apple D0-D7 -> U2 74LVC245 -> Pico GP0-GP7 /DEVSEL OR R/W -> U1 74LVC32 -> Pico GP8 (/WRSEL)
Both logic chips run from the Pico's 3.3 V rail, not the Apple's +5 V. LVC inputs carry no clamp diode to VCC and are specified to 5.5 V independent of VCC, so feeding them 5 V Apple TTL is the datasheet-supported case rather than a tolerated one. That is what removes the need for series resistors, and it means power sequencing does not matter.
The PIO program keeps the newest data sample taken wholly inside the /WRSEL low pulse and pushes it when the strobe rises. This matters: a 6502 does not drive valid data until well after /DEVSEL falls, so sampling at the start of the window would latch garbage. Sampling at the end is what conventional Apple II cards do with a '374.
The bus state machine runs on PIO1 and the I2S implementation on PIO0, so the two never contend for a state machine. The firmware disables the internal pulls on GP0-GP7 and enables a pull-up only on GP8.
The card
Left to right across the top: the speaker, the I2S GAIN DIP switch SW2 above the MAX98357A I2S amplifier, the PAM VOLUME trimmer RV1 above the HW-104 PAM8403 class-D module, and the Raspberry Pi Pico with the reset button SW1 beside it. Along the bottom: the speaker selector J7 with its two shunts at the far left, the PWM filter and gain resistors, U2 (74LVC245, the wide SOIC-20) and U1 (74LVC32, SOIC-14), and the supply Schottky D1 at the right-hand end. The slot edge connector is J1.
The Pico and both amplifier modules plug into pin headers; everything else is soldered to the board, the two logic chips directly as SOIC parts.
Gerbers
pcb/gerbers-v2.zip is the fabricated revision 2 board, exported from KiCad:
| Size | 149.9 × 77.4 mm |
| Layers | 2, 1.6 mm |
| Minimum track and clearance | 0.2 mm |
| Smallest drill | 0.3 mm |
| Files | copper, mask, paste and silkscreen for both sides, edge cuts, PTH and NPTH drill, KiCad job file |
The job file leaves the surface finish unspecified. The card seats in an Apple II slot, so a hard-wearing finish on the edge fingers is worth choosing when ordering.
Bill of materials
Designators match the board silkscreen and perfectpaul2.net.
| Ref | Qty | Value | Part / footprint | Function |
A1 | 1 | Raspberry Pi Pico | on 2 × 20 pin headers | RP2040 module |
U1 | 1 | 74LVC32 | SOIC-14, 3.9 mm body | /WRSEL strobe gate |
U2 | 1 | 74LVC245 | SOIC-20, 7.5 mm wide body | data bus buffer |
D1 | 1 | 1N5817 | DO-41 Schottky | Apple +5 V into the card's own rail |
R1, R2 | 2 | 10 kΩ | axial | pull-ups on R/W and /DEVSEL |
R3, R4 | 2 | 1 kΩ | axial | PWM low-pass, series elements |
R5, R6 | 2 | 100 kΩ | axial | gain selector legs |
R7 | 1 | 1 kΩ | axial | gain selector current limit |
RV1 | 1 | 20 kΩ | Piher PT-6 vertical trimmer | PAM8403 volume |
C1, C2 | 2 | 22 nF | ceramic disc, 5 mm pitch | PWM low-pass, shunt legs |
C3 | 1 | 10 µF | radial electrolytic, 5 mm | PWM DC block, + toward the filter |
C4, C5 | 2 | 100 nF | ceramic disc | decoupling at U1 and U2 |
C6 | 1 | 100 nF | ceramic disc | reset debounce, across SW1 |
C7 | 1 | 10 µF | radial electrolytic, 5 mm | reservoir on the 5 V card rail |
C8 | 1 | 100 nF | ceramic disc | decoupling on the 5 V card rail |
SW1 | 1 | — | 6 mm tactile push button | reset |
SW2 | 1 | — | 4-position DIP slide switch | MAX98357A gain |
J1 | 1 | — | Apple II card-edge fingers | slot connector |
J2, J3, J4 | 3 | — | 1 × 7 pin header, 2.54 mm | amplifier module sockets |
J5, J6 | 2 | — | 1 × 2 pin header | speaker, MAX98357A speaker output |
J7 | 1 | — | 2 × 3 pin header + 2 shunts | speaker source selector |
Modules and off-board parts:
| Qty | Part | Notes |
| 1 | MAX98357A I2S amplifier breakout | Adafruit pinout; plugs into J2 |
| 1 | PAM8403 class-D module (HW-104) | plugs into J4 and J3 |
| 1 | Small 4–8 Ω speaker | to J5; keep speaker power modest when drawn from the slot |
Both amplifiers can stay fitted; J7 chooses which one drives the speaker. A card built for one backend only needs just that module.
Schematic
Electrical approach
Everything on the card except the Apple bus itself and the amplifier supply runs at 3.3 V, taken from the Pico's 3V3_OUT pin (physical pin 36): U1 and U2 are both powered from it.
The LVC family is the right part for this job for one specific reason: its inputs have no clamp diode to VCC. The datasheet specifies the I/O pins to 5.5 V independent of VCC, including VCC = 0 (the Ioff partial-power-down specification). Feeding 5 V Apple TTL into a 3.3 V-powered LVC input is therefore the manufacturer-supported case. 74HC or 74LV parts would not do: their input clamp diodes would conduct Apple +5 V into the 3.3 V rail.
What that buys:
- No series resistors.
U2's B outputs are push-pull CMOS on the same 3.3 V rail as the Pico's inputs, so there is no overvoltage to limit. - No power-sequencing hazard. The 5 V tolerance holds at VCC = 0, so it does not matter whether the Apple's +5 V or the Pico's 3.3 V comes up first.
- A light load on the Apple data bus — a few microamps per line.
Voltage thresholds line up with no translation trick. LVC at VCC = 3.0–3.6 V specifies VIH = 2.0 V and VIL = 0.8 V, and Apple TTL levels (≥ 2.4 V high, ≤ 0.5 V low) sit comfortably inside them.
Bus interface
Apple II slot 3.3 V logic Pico D0 (pin 49) ---------------> U2 A0 U2 B0 ------------------------> GP0 D1 (pin 48) ---------------> U2 A1 U2 B1 ------------------------> GP1 ... ... D7 (pin 42) ---------------> U2 A7 U2 B7 ------------------------> GP7 /DEVSEL (pin 41) --+-- R2 10k --> 3V3 \ U1 gate 1, 74LVC32 OR --------------------------> GP8 / R/W (pin 18) ------+-- R1 10k --> 3V3 /WRSEL = /DEVSEL OR R/W
/WRSEL is low only for a write to the selected slot's $C0n0-$C0nF device window. The Pico only receives bus signals and never drives the Apple II data bus. The data pins run backwards on the slot: D7 is pin 42 and D0 is pin 49.
R1 and R2 are not optional. U1 runs from the Pico's 3.3 V rail, so it is live whenever the Pico is — on the bench over USB, and with the card installed while the Apple II is switched off. In that state /DEVSEL and R/W float, two floating CMOS inputs can settle low, /WRSEL asserts on its own, and the synthesiser speaks noise. 10 kΩ to 3V3 holds them high when the Apple is not driving them, and is invisible when it is.
No address lines are decoded: A0–A15, /IOSEL, /IOSTROBE, /RES and the interrupt and DMA daisy chains on J1 are all unconnected.
U2: 74LVC245 pin by pin
| Pin | Name | Connection |
| 1 | DIR | 3.3 V — A to B, permanently Apple to Pico |
| 2–9 | A0–A7 | Apple D0–D7, slot pins 49 down to 42 |
| 10 | GND | ground |
| 11–18 | B7–B0 | Pico GP7 down to GP0 |
| 19 | /OE | ground — always enabled |
| 20 | VCC | 3.3 V, decoupled by 100 nF |
/OE low is intentional. Direction is fixed Apple-to-Pico, so the A side is always an input and U2 cannot drive the Apple bus; the PIO only captures while /WRSEL is low.
U1: 74LVC32 pin by pin
| 1 | 1A | Apple /DEVSEL, slot pin 41, and R2 10 kΩ to 3.3 V |
| 2 | 1B | Apple R/W, slot pin 18, and R1 10 kΩ to 3.3 V |
| 3 | 1Y | Pico GP8, directly |
| 4, 5, 9, 10, 12, 13 | unused inputs | ground |
| 6, 8, 11 | unused outputs | no connection |
| 7 | GND | ground |
| 14 | VCC | 3.3 V, decoupled by 100 nF |
The unused inputs are grounded deliberately: a floating CMOS input can sit near mid-rail, drawing crowbar current and oscillating.
Pico connections
These are the only Pico pins the card uses.
>td >Ground
| Function | GPIO | Physical pin | Connection |
| D0–D7 | GP0–GP7 | 1, 2, 4, 5, 6, 7, 9, 10 | U2 B0–B7 |
/WRSEL | GP8 | 11 | U1 pin 3 |
| I2S LRCLK / WS | GP21 | 27 | J2 pin 1, MAX98357A LRC |
| I2S BCLK | GP20 | 26 | J2 pin 2, MAX98357A BCLK |
| I2S data | GP22 | 29 | J2 pin 3, MAX98357A DIN |
| PWM audio | GP28 | 34 | R3, into the low-pass filter |
| Reset | RUN | 30 | SW1 and C6 to ground |
| 3.3 V out | 3V3_OUT | 36 | U1, U2, R1, R2, C4, C5 |
| Card power in | VSYS | 39 | D1 cathode |
| GND | 3, 8, 13, 18, 23, 28, 38 | all seven tied to ground |
Left unconnected: VBUS (pin 40), 3V3_EN (37), ADC_VREF (35), AGND (33), and GP9–GP19, GP26, GP27. GP25 is the on-board LED, which the firmware uses as a ready indicator.
Two pins are worth never touching by hand:
- VBUS, pin 40, is USB +5 V. The card feeds
VSYS, pin 39, one pin away; feedingVBUSinstead would defeatD1and back-feed the Apple's +5 V rail from USB. - 3V3_EN, pin 37. Grounding it disables the Pico's regulator, which also takes
U1andU2down.
Nothing else may drive GP0–GP7: U2 drives all eight push-pull, with nothing in series. GP0 and GP1 are UART0's default pins, so CMakeLists.txt disables UART stdio and main.c fails the build if it is ever re-enabled. Debug output goes over USB CDC.
Power
Apple +5 V (slot pin 25) --->|--- VCC, the card's 5 V rail ---+--> Pico VSYS (pin 39) D1 1N5817 +--> J2 pin 7, MAX98357A Vin +--> J4 pin 6, PAM8403 5 V +--> R6, R7 (gain selector) +--> C7 10 uF + C8 100 nF Pico 3V3_OUT (pin 36) -------------------------------------------> U1, U2, R1, R2, C4, C5 Apple GND (slot pin 26) -----------------------------------------> common ground
D1 stops USB power applied to the Pico from feeding back into the Apple II's +5 V rail. It is a Schottky because its drop lands directly on the amplifier supply, and 0.4 V costs less output power than a 1N400x's 0.7 V. Everything the card powers is on the cathode side, so the amplifiers also work when the card runs from USB on the bench. On the board, the band on D1 — the cathode — faces away from the slot connector.
C7 and C8 sit beside the amplifier headers, where the current is drawn. C8 handles the amplifiers' switching frequency; C7 covers the audio range, so the rail does not sag on loud passages. The logic load on 3V3_OUT is well under a milliamp, nowhere near the Pico regulator's budget.
Never connect Apple +5 V to 3V3_OUT.
Reset button
SW1 grounds the Pico's RUN pin; release it and the card reboots and speaks its ready message again. C6, 100 nF, is in parallel with the button and debounces it against RUN's internal pull-up of about 50 kΩ (a 5 ms time constant). No external pull-up is needed.
Hold BOOTSEL, tap SW1, release BOOTSEL, and the Pico comes up as its USB bootloader drive — reflashing without pulling the card or the cable. The Apple II's own reset does not reach the card: slot pin 31 (/RES) is not wired, so Ctrl-Reset leaves the Pico running.
Connectors
| Ref | Pins | Connection |
J1 | card edge | Apple II slot |
J2 | 1 × 7 | MAX98357A: 1 LRC, 2 BCLK, 3 DIN, 4 GAIN, 5 SD, 6 GND, 7 Vin |
J6 | 1 × 2 | MAX98357A speaker output: 1 −, 2 + |
J4 | 1 × 7 | PAM8403 input and power: 1 L in, 2 GND, 3 R in, 6 5 V, 7 GND |
J3 | 1 × 7 | PAM8403 speaker output: 6 +, 7 − |
J7 | 2 × 3 | speaker source selector, see Selecting the amplifier |
J5 | 1 × 2 | the speaker: 1 +, 2 − |
J2 follows the Adafruit MAX98357A breakout's own pinout, so the module drops straight on. J4 pins 1 and 3 carry the same mono signal, since the PAM8403 is a stereo part fed one channel. J3 and J4 are seven-pin headers because that is the module's pin spacing; the unlisted pins are unconnected. SD on J2 pin 5 is left open, so the MAX98357A is always enabled.
Build
The firmware is a target for DECtalkMini. This repository deliberately does not vendor that tree — see Licensing. Fetch it yourself and drop this target in:
git clone https://github.com/dectalk/DECtalkMini cp -r pico-apple2 DECtalkMini/platforms/ export PICO_SDK_PATH=/path/to/pico-sdk export PICO_EXTRAS_PATH=/path/to/pico-extras cd DECtalkMini/platforms/pico-apple2 cmake --preset pico-pwm-release # or pico-i2s-release cmake --build --preset pico-pwm-release
Requires Pico SDK 2.x and pico-extras. Two executables are produced:
dectalk_apple2.uf2— the card firmwaredectalk_selftest.uf2— speaks a phrase loop with no Apple II and no slot wiring attached, for bringing up the audio path on its own
Build the self test with the same preset as the firmware. It follows DECTALK_AUDIO_I2S, so a self test built for the other backend is silent by construction and tells you nothing about the one you are actually using.
Talking to it from a terminal
The firmware keeps USB CDC as a bench input using the same line protocol as the slot, so you can drive the card with no Apple II attached. tools/paul-say.sh wraps that:
./tools/paul-say.sh "Hello from the terminal." ./tools/paul-say.sh # interactive, Ctrl-D to quit ./tools/paul-say.sh -l # just listen to the card's output
It is the fastest way to audition DECtalk phrasing, including phoneme spellings, without rebuilding and reflashing. If you would rather use minicom: turn hardware flow control off. It defaults to on, the Pico's CDC never asserts CTS, and the card then ignores everything you type and looks dead. Never open the port at 1200 baud either - that is the Pico's BOOTSEL-reset trigger.
If the build fails to link
Older DECtalkMini checkouts fail on every NO_FILESYSTEM target with region RAM overflowed — the 390 KB dictionary lands in .data and overflows the RP2040's 264 KB of SRAM. This was issue #40, fixed upstream in August 2026. If you hit it, update DECtalkMini. Verify with arm-none-eabi-size -A: main_dict belongs in .rodata, and .data should be about 25 KB, not about 424 KB.
The spoken ready message
The card says "Perfect Paul Two ready." when the Apple II is switched on. DECTALK_SPEAK_STARTUP_BANNER is ON by default; build with -DDECTALK_SPEAK_STARTUP_BANNER=OFF for a silent boot. The wording lives in DECTALK_STARTUP_BANNER_TEXT at the top of main.c.
That string spells "perfect" phonemically, as [:phone arpa speak on][prrfihkt][:phone arpa speak off], and should not be simplified back to plain text. perfect has no entry in dic/dtalk_us.dic, so it falls through to the letter-to-sound rules and is stressed as the verb, per-FECT — nearly every other English -ect word takes final stress (affect, collect, correct, detect). paul, two and ready all have dictionary entries and stay as ordinary text. Keep the trailing \x0b, which is what tells DECtalk to speak the buffer.
It is spoken after core 1 signals readiness, so the card is already accepting slot writes while it announces itself. Note this is a power-up message, not a reset message: slot pin 31 (/RES) is not wired to the Pico's RUN pin, so Ctrl-Reset does not re-trigger it.
Audio
Both paths work on the card. PWM is GP28 through a filter into the PAM8403; I2S is GP20/21/22 into the MAX98357A. Audio quality is indistinguishable between them. Which one the firmware drives is chosen at build time (pico-pwm-release or pico-i2s-release); which one reaches the speaker is chosen with J7.
GP28 cannot drive a speaker directly — the PWM path always needs an amplifier behind its filter.
PWM output filter
DECtalk here is an 11025 Hz stream with nothing above 5.5 kHz, while pico_audio_pwm carries a ~353 kHz 1-bit carrier. That gap is enormous, so filtering hard costs nothing. Two poles near 7 kHz, then a DC block into the volume trimmer:
GP28 --[R3 1k]--+--[R4 1k]--+--|(--+ | | C3 | C1 22nF C2 22nF 10uF RV1 20k ---> PAM8403 L and R in | | + on the | GND GND filter side GND
| Ref | Value | Function |
R3, R4 | 1 kΩ | series elements of the two-pole low-pass |
C1, C2 | 22 nF | shunt legs, 1/(2π·1k·22n) = 7.2 kHz per section |
C3 | 10 µF, + toward the filter | DC block; the PWM node idles around 1.65 V |
RV1 | 20 kΩ | volume trimmer, wiper into the PAM8403 |
C3's orientation follows from the two DC potentials: the filter side sits at the PWM output's average, about 1.65 V at idle, while RV1 holds the other side at 0 V. So + faces the filter — the opposite of the usual rule of thumb that a coupling capacitor's + faces the amplifier input.
RV1 at 20 kΩ is high enough not to disturb the filter. The two RC sections are unbuffered and load each other, so the real response is not a textbook two-pole, but it still suppresses the carrier far better than a single pole. That matters most with a class-D amplifier, which switches at a few hundred kHz itself and would intermodulate with any surviving carrier.
Both are bridge-tied-load class-D amplifiers: on both, the speaker − terminal is not ground but a second switching output driven antiphase to +. So:
- Never ground a speaker output on either module. It shorts a half-bridge.
- Never tie the two modules'
−outputs together. That parallels two active drivers.
Both speaker leads are therefore switched, by J7, a 2 × 3 header carrying two shunts. The middle row is the speaker and each outer row is one amplifier:
left column right column row 1 1 I2S- 2 I2S+ MAX98357A row 2 3 SPK- 4 SPK+ to the speaker row 3 5 PAM- 6 PAM+ PAM8403
| To select | Fit shunts |
| I2S (MAX98357A) | 1–3 and 2–4 |
| PWM (PAM8403) | 3–5 and 4–6 |
Both shunts go vertically, one per column. Every horizontal position is destructive: 1–2 shorts the MAX98357A's two outputs, 5–6 the PAM8403's, and 3–4 shorts the speaker leads across whichever amplifier is selected. Never fit four shunts. Unlike a DPDT switch, the header has no make-before-break moment that could bridge both amplifiers on the way past. Leaving the unselected amplifier powered into an open circuit is harmless.
The gain selector
The MAX98357A picks one of five gains from what its GAIN pin is tied to. SW2 is a 4-position DIP; position N bridges pin N to pin 9−N:
| Position | Connects GAIN to | Gain |
| 1 | ground via R5 100 kΩ | 15 dB |
| 2 | ground directly | 12 dB |
| 3 | 5 V via R7 1 kΩ | 6 dB |
| 4 | 5 V via R6 100 kΩ | 3 dB |
| none closed | floating | 9 dB |
Close at most one — the silkscreen reads SELECT ONE!. Four positions cover all five gains, because "floating" is simply every switch open.
R7 makes a wrong setting harmless rather than destructive. Without it, closing positions 2 and 3 together would short the 5 V rail straight to ground through two switch contacts. With 1 kΩ in that leg the worst case is 5 mA, and no combination of positions can short the rail. 1 kΩ is small enough against the MAX98357A's internal GAIN bias network that position 3 still reads as "tied to 5 V".
Clock and supply notes
The I2S build runs the RP2040 at the default 125 MHz, because pico_audio_i2s derives its own dividers from clk_sys. The PWM build runs at 96 MHz: pico_audio_pwm's PIO program assumes a 48 MHz PIO clock and the library never sets a divider, so at 125 MHz everything plays 2.6× too fast. 96 MHz with an exact ÷2 keeps DECtalk twice the CPU budget that set_sys_clock_48mhz() would leave it. The bus interface works at both clocks.
Keep speaker power modest when drawing it from the slot: an amplifier at volume can pull most of an amp from +5 V, which is acute on an Apple II+ whose supply is already loaded by its DRAM and a Language Card.
Demo programs
In basic/, all verified on hardware. Renderings of what they should sound like are in audio/, produced from the DECtalk native build so you can listen without an Apple II.
A ready-to-boot 140 KB image with all of them installed is in disk/perfect-paul.dsk - boot it and RUN any of the names below. It is a ProDOS disk, so it carries Apple's PRODOS.SYS and BASIC.SYSTEM alongside the programs; those are Apple's, are not covered by this repository's licence, and are there only to make the disk bootable. The listings in basic/ are the source of record, and Rebuilding the disk image below shows how to regenerate the disk from them.
| Program | What it does |
SPEAK.bas / APPLESPEECH.bas / PERFPAUL.bas | Type a line, hear it spoken |
DAISY.bas | Sings Daisy Bell in phoneme mode, ~23 s |
ELIZA.bas | A talking Weizenbaum-style therapist |
SINGCOMP.bas | Nine voices hold a singing competition, then argue about it |
YELSUB.bas | Sings Yellow Submarine, 59 s of music in 23 phrases |
VOICES.bas | A sung four-part greeting, then all nine voices introduce themselves |
HAL.bas | Paul reshaped into HAL 9000 |
MANGER.bas | Away in a Manger, 58 s |
ANGELS.bas | Angels We Have Heard on High, 35 s |
BLOWMAN.bas | Blow the Man Down, 14 s |
DAISY uses [:phone arpa speak on] with explicit <duration,pitch> on each phoneme. The arrangement comes from the author's own sing_daisy() in Talker-80. DECtalk note n maps to MIDI note n+35, so n=10 is A2 at 110 Hz if you want to transpose it.
ELIZA has 21 keywords with rotating responses, pronoun reflection, and generic fallbacks, and speaks every reply. It reads input with GET rather than INPUT, because INPUT splits on commas and prints EXTRA IGNORED the moment anyone types one.
The VCF West 2025 demos
SINGCOMP, YELSUB, VOICES and HAL are translated from the DECtalk DTC01 demos on the Talker/80 Model III disk shown at VCF West 2025, in Talker-80. Those demos drive a real DTC01 over a serial port; the TRS-80 side is a loop that pushes the bytes of a text file out through USR calls. The transport has nothing in common with a POKE to a slot register, but the DECtalk payload is identical, which is what makes them portable at all.
The Talker/80 demos on the same disk are not directly portable, but not because they use some other synthesiser family. Talker/80 drives an Epson S1V30120, which carries a DECtalk version 5 image - the same part, and the same image, as the Emic 2. So both sides of that disk speak DECtalk. The gap is one of version, not of language.
DECtalkMini is a different and older DECtalk generation; its [:version] response reports 4.99, and its command set is closer to the DTC01's than to V5's. That is precisely why the DTC01 demos carried over with no command changes at all, while the Talker/80 demos assume V5-era syntax and would need adapting phrase by phrase.
(If you have met Talker/80 or LambdaSpeak's SP0256-AL2 mode, note that is an emulation layered on DECtalk, not an SP0256 part. There is no SP0256 anywhere in this story.)
Two things had to change beyond the transport:
VOICESused[:nv], a user-defined voice this DECtalk build does not have, which would have spoken an error. Dennis and Wendy replace that line - which makes the count genuinely nine, where the original narration promised nine and delivered eight.YELSUBarrives as two bracketed groups of 39 s and 20 s. Both are far past the 254-character limit on one utterance, so they are split at the,<100,20>phrase markers into 23 utterances.
Pacing, and why these need it
The card is write-only. There is no status register and no flow control, and its line queue holds 8 utterances. When that queue fills, the firmware blocks core 0, which stops draining the bus FIFO, and further writes are silently dropped - you hear speech garble rather than an error.
DAISY never hits this because it sends only five utterances. SINGCOMP sends 23 and YELSUB 23, so both have to pace themselves. Each DATA item carries its own length in milliseconds, exact for sung phrases because the durations are in the notation:
2000 DATA "[IH<250,24>N DHAX<150,25> TAW<750,27>N ...]",2350
and the wait is
950 WT = MS * .9 * PF - LEN (S$) * SD
MS * .9 converts milliseconds to loop iterations, since about 900 empty Applesoft FOR/NEXT iterations take a second. The second term matters more than it looks: POKE DR, ASC ( MID$ (S$,I,1)) over a 140-character phrase takes roughly half a second on a 1 MHz 6502, which was 63% of the gap before it was accounted for.
Two knobs, both at the top of each program:
| Default | Raise it if | Lower it if | |
PF | .9 | speech garbles | you want it tighter still |
SD | 3 | long phrases lag but short ones do not | long phrases run ahead |
PF = .9 deliberately runs slightly ahead of real time, letting the 8-deep queue absorb the lead so phrases play back to back. That turns the queue from a hazard into the thing that makes singing gapless. .8 still only reaches about 4 utterances deep; .7 gets close to filling it and risks dropped characters.
SD is an estimate of the Applesoft send loop, not a measurement, so it is the one to reach for if the gap scales with phrase length.
Getting a demo off a TRS-80 disk
The DTC01 demos started life on a Model III floppy. tools/trs80-extract.py reads a JV3 image, lists its TRSDOS directory, and pulls files out - detokenizing Level II BASIC on the way:
tools/trs80-extract.py VOICDEMO.jv3 --list tools/trs80-extract.py VOICDEMO.jv3 --cat 'SINGCOMP/TXT' # a text file tools/trs80-extract.py VOICDEMO.jv3 --cat 'SEND FILE' --detok # a BASIC program tools/trs80-extract.py VOICDEMO.jv3 --raw > flat.img # ordered sectors
Extraction is a content scan over the ordered sector image rather than a walk of TRSDOS granule chains, which is enough for the contiguous files these demo disks use. One wrinkle it handles for you: a search string often appears twice - once inside a tokenized BASIC program and once in the standalone data file - so for a text extract it takes whichever occurrence yields the longest clean run, and stops at the first non-text byte rather than running on into the rest of the disk.
Adding a song to the disk
End to end, a DECtalk song file becomes a program on the disk in three steps. ANGELS is used throughout as the example; substitute your own name, up to 15 characters, letters and digits, starting with a letter.
# 1. translate: DECtalk song file -> paced Applesoft listing tools/dt2applesoft.py "ANGELS WE HAVE HEARD ON HIGH.txt" \ --title "ANGELS WE HAVE HEARD ON HIGH" \ --credit "traditional, public domain" > basic/ANGELS.bas # 2. import: listing -> tokenized Applesoft on the disk java -jar AppleCommander-ac.jar -bas disk/perfect-paul.dsk ANGELS < basic/ANGELS.bas # 3. verify: read it back and confirm nothing was mangled java -jar AppleCommander-ac.jar -l disk/perfect-paul.dsk | grep ANGELS java -jar AppleCommander-ac.jar -e disk/perfect-paul.dsk ANGELS | diff - basic/ANGELS.bas
Do not skip step 3. The diff will show cosmetic reformatting from the detokenizer - .9 prints as 0.9, -16192 as - 16192, spacing shifts - so what you are looking for is a line going missing, which is what the bare-REM bug does. See Rebuilding the disk image.
Then RUN ANGELS from the ] prompt. On real hardware the disk image also has to reach the machine, which on a Floppy Emu means copying it to the SD card as well - editing the image in place is not enough.
What the translator handles
Together with trs80-extract.py above, these two cover the whole path from a TRS-80 floppy to a program on an Apple II disk. AppleCommander is the one piece not vendored here - it is a separate GPL project with its own releases, linked below.
tools/dt2applesoft.py exists so none of this has to be redone by hand.
It handles the parts that are easy to get wrong:
- Splitting. A song often arrives as one bracketed group of several hundred characters; the firmware truncates an utterance at 254 and Applesoft will not accept a line over 239. Both ceilings are hard limits.
Words are never split. In this notation a word like
IH<250,24>Nis one unit meaning "in" - the timing rides on the first phoneme and the rest of the word follows inside the same unit - so whitespace is the only word boundary. Breaking betweenIH<250,24>andNputs half a word in the next utterance, which is plainly audible. Some files carry no whitespace at all, the whole song being a single enormous word; only then does the splitter fall back to cutting at phoneme tokens, because there is nothing else to cut at.Where inside the budget it breaks decides how the rest sounds. Among the break points in the last 45% of a full chunk it breaks after the word carrying the longest duration: a long note usually ends a sung phrase, so the seam falls where a singer would breathe. On the carols here that lifted the mean note at a seam from about 300 ms to about 730 ms.
- Timing. Each utterance's length is summed from its
<duration>fields and written into theDATAline, so the pacing is derived rather than guessed. - Voices. Some files ask for
[:nv], a user-defined voice this build does not have and which would speak an error. The tool substitutes a real one and records the substitution in aREM. - Command spelling. Files in the wild use
[:phone on],[:phoneme arpabet on]and other variants; all are normalised to[:phone arpa speak on], the spellingDAISYproved on hardware. [:dv]voice shaping is dropped unless you pass--keep-dv, because support for it here is unverified and an unrecognised command is spoken rather than ignored.
It refuses to emit rather than produce a listing that would fail: over-long lines, over-long utterances, or a bare REM line.
A note on what to translate
The three carols above are traditional and long out of copyright, which is why they are here. Much of the DECtalk song archive is not - it is largely recent popular music, and a phoneme transcription is still the lyric. Translating whatever you like for your own disk is one thing; publishing it is another. The tool works on any input, and that choice is yours to make.
AppleCommander imports a listing as tokenized Applesoft:
java -jar AppleCommander-ac.jar -bas disk/perfect-paul.dsk SINGCOMP < basic/SINGCOMP.bas
Never leave a bare REM line in a listing you import. AppleCommander's tokenizer makes it swallow the following line, so
140 REM 150 DR = - 16192
becomes one comment, DR is never assigned, and every POKE DR,... goes to zero page. It looks exactly like a dead card. Verify any import by exporting it again with -e and diffing the quoted literals; the detokenizer reformats numbers (.9 prints as 0.9, -16192 as - 16192), so compare literals rather than whole lines.
Changing the slot
Every demo program ships set to slot 4. Each one sets DR on exactly one line, so switching slots is a one-line edit — no other change is needed anywhere:
| Program | Line to change |
DAISY.bas | 30 DR = -16192: REM SLOT 4 ($C0C0) |
ELIZA.bas | 30 DR = -16192: REM SLOT 4 ($C0C0) |
SPEAK.bas, APPLESPEECH.bas, PERFPAUL.bas | 10 DR = -16192 |
Substitute the value for your slot from the table above. For a card in slot 5, for instance:
]LOAD ELIZA ]30 DR = -16176: REM SLOT 5 ($C0D0) ]SAVE ELIZA ]RUN
If you would rather not edit anything, compute it at run time from a slot number — $C080 is -16256, and each slot is 16 bytes further on:
10 S = 5 : DR = -16256 + 16 * S
That form is worth using in your own programs, since it makes the slot a single obvious constant at the top rather than a magic negative number.
Nothing to change in the firmware
Slot selection is only a BASIC concern. The card decodes no address lines, so the same .uf2 runs unmodified in any slot — there is no build option, jumper, or constant to set. Moving the card between slots needs no reflash.
Inline command gotcha
DECtalkMini lists voices by name only — np, nb, nh, nf, and so on. The numeric form [:n0] that some other DECtalk implementations accept is rejected, and the rejection is spoken aloud as a ~1.5 second error while the rest of the utterance still works.
That failure mode generalises: an unrecognised command does not fail silently or visibly, it just adds speech. Comparing two renders that both contain the error will never reveal it. Render with the native say build and compare duration against a known-good baseline instead.
The final board passed all of these. Run them on any new build.
Before power:
- Check
U1andU2orientation. SOIC parts often have no notch: with the marking reading normally, pin 1 is lower left. - Check
D1: the band faces away from the slot connector. - Check
C3's andC7's polarity against the silkscreen. - Fit exactly one
J7shunt pair, vertically, and at most oneSW2position.
A genuine LVC part matters. With a multimeter on diode test, black probe on VCC and red on any input, a real 74LVC part reads open — LVC omits the upper clamp diode, which is exactly the 5 V tolerance this design relies on. A reading near 0.6 V means an HC, HCT or LV part, which would inject Apple +5 V into the 3.3 V rail.
With power:
- With the Apple II on and the card installed,
U1andU2VCC sit at about 3.3 V, not 5 V. - The 5 V card rail reaches Pico VSYS, not VBUS, about one Schottky drop below the Apple +5 V.
U2's A-side pins swing to about 5 V and its B-side pins to about 3.3 V. Equal swings mean the buffer is not translating.- GP8 is normally high and pulses low only during a write to the card's
$C0nXwindow. - With the Apple II off and the Pico on USB, GP8 still reads high. If it sits low,
R1orR2is missing. - GP0–GP7 match the written byte while GP8 is low.
Validation status
The final revision 2 card works in a real Apple II, assembled from the published Gerbers and the bill of materials above. A POKE to the card's device window produces intelligible speech, the card announces itself at power-up, and the demo programs run.
What bring-up established about the design, and what the final board confirms:
- The 74LVC interface. 5 V Apple TTL into
74LVC245and74LVC32powered from the Pico's3V3_OUT, with no series resistors anywhere, translating correctly in a live machine. - The PIO capture protocol in
apple2_slot_rx.pio. This was the one thing that could not be settled analytically: at the end of a write cycle the 6502's data-hold time (spec minimum 10 ns) races the decoder's/DEVSELde-assert delay, so the last sample inside the low pulse could in principle catch a released bus. It does not. Slot bus capacitance holds the byte well past the datasheet minimum — the same reason a conventional '374-latched card works. - Slot wiring, including the data pins running backwards.
- The core-0 receive / core-1 synthesis split under real bus traffic, and the
\rto\x0bline protocol. PWM and I2S each run their DMA IRQ on core 1 beside the synthesis callback, leaving core 0's slot poll uninterrupted. /WRSEL = /DEVSEL OR R/Wcorrectly ignoring read cycles to the same window.- The bus at both system clocks, 96 MHz and 125 MHz.
apple2_slot_rx.piois fully asynchronous — no delay cycles and no clock divider — so a faster clock only samples more often inside the/WRSELwindow. - Both speech self tests (
dectalk_selftest.uf2from each preset) speak their phrase loop at the correct pitch with no Apple II attached, covering DECtalk synthesis, the embedded dictionary and each audio path on its own.
Software exercised on the card
Two Applesoft programs run correctly from ProDOS on the real machine, and between them they cover the three ways the card gets used:
DAISYsings Daisy Bell. This exercises DECtalk's phoneme/singing mode:[:phone arpa speak on]plus explicit<duration,pitch>on every phoneme, in five utterances totalling about 23 seconds. It confirms that inline bracketed commands survive the slot transport intact, which plain text does not prove — a single corrupted byte inside[...]would derail the parser.ELIZAis interactive. This is the stronger test: sustained back-and-forth across a whole session rather than one scripted burst, with variable-length replies, and an ApplesoftGET-based input loop running alongside thePOKEstream. It exercises the firmware's line queue and the core-0/core-1 handoff under realistic traffic.
Together with the earlier self test, the card is now exercised on plain text, phoneme/singing mode, and interactive use.
Not measured
The card works; these have not been instrumented:
- Logic-analyzer timing of
/DEVSEL,R/W,/WRSELand D0–D7. The margin at the end of the write window is inferred, not measured. - Signal integrity on the board, long-run stability, thermal behaviour, and slot current with a particular amplifier and speaker.
- Audio quality, beyond listening.
- Other machines. The five signals used are common to the II, II+ and IIe, so the design should be model-independent, but it has been tested in one machine.
There is no hardware flow control. PIO captures each selected write into an eight-word FIFO, which is ample for POKE traffic; a tightly optimised 6502 loop writing a continuous stream can overrun it.
How this was verified
The development record behind the claims above:
- Audited the GPIO and PIO setup against the 74LVC interface: pins are inputs, pulls disabled on GP0-GP7, pull-up retained on GP8,
wait 0 pin 8resolves to GP8 via the IN base andjmp pinto absolute GP8. No functional change was required. - Confirmed
LIB_PICO_STDIO_UARTis absent from the compiled definitions, so the GP0/GP1 contention guard reflects the build as configured, and verified the guard fires when UART stdio is forced on. - Cross-built both CMake presets for RP2040 with the Arm GNU toolchain.
- Compared the adapter target with the supplied DECtalkMini Pico SDK target and retained its core-1 synthesis/audio arrangement.
- Reviewed the PIO program instruction by instruction. It uses one state machine and a joined eight-word RX FIFO.
- Confirmed against the native build that DECtalk's dictionary lookup, its inline
[:xx]commands, and arpabet phoneme symbols are all case-insensitive, so Applesoft's uppercase-only text needs no special handling. - Measured the singing pitch scale against the native build: DECtalk note n maps to MIDI note n+35, so n=10 is A2 at 110 Hz.
- Established that DECtalkMini rejects the numeric voice form
[:n0]and speaks a ~1.5 second error while otherwise working normally. The command table ininclude/c_us_cde.hlists voices by name only (np,nb,nh, ...). Use[:np]for Perfect Paul. Abbreviated forms such as[:phone arpa speak on]and[:rate 200]are accepted. - Verified every
DATAstring in both BASIC programs by reading it back out of the ProDOS image and rendering from the read-back copy, not from the local source. - Validated the Eliza engine as a Python transliteration — keyword priority, pronoun reflection, response rotation — before emitting the Applesoft.
None of these is needed; the board works as published.
- A true gain selector — a six-pin header with one shunt, or a rotary switch — would make an invalid setting unreachable rather than harmless.
- A non-polarised
C3would remove its orientation constraint. Anything from 1 µF upward keeps the high-pass corner intoRV1below DECtalk's roughly 80 Hz floor. - Slot
/REStoRUNthrough one ofU1's spare gates, if the ready message should repeat on Ctrl-Reset. Keep any reset button on the gate's input side, or it shorts the gate output.
Historical record
The card went through two builds before the final board. Every photograph of them is kept here; none of these is a supported design.
Hand-wired prototype
The first working card, on an Apple II prototyping board. The first PWM speech came from this board.
How it differs from revision 2:
- Point-to-point wiring on perfboard, with the slot fingers wired by hand, and the two SOIC logic chips on SOIC-to-DIP breakout adapters.
- PWM only, through a PAM8403 module. No I2S amplifier.
- No output filter: two 100 kΩ resistors in series as a divider, no capacitors.
- No supply diode, no reset button and no reservoir capacitor.
- Speaker on flying leads, with no selector.
Revision 1 PCB
The first fabricated board, and the one both audio paths were brought up on.
- No
D1. Apple +5 V reached the Pico'sVSYSundiode, so USB power could back-feed the Apple's rail. - No speaker selector. Both amplifiers were fitted with the speaker on flying leads, moved by hand between them.
- A 5-position gain DIP with two directly tied legs, one pair of which shorted 5 V to ground. The silkscreen said SET ONLY ONE; revision 2's 4-position
SW2withR7makes any combination safe. - No reset button; reflashing meant unplugging USB.
- No capacitor on the 5 V rail at the amplifier headers.
C3reverse biased by about 1.65 V.- Schematic values that
Michael Wessel
