27 — Ceylon Development Log — September 14, 2026: Strengthening the Foundation
A project log for Project Ceylon: What If the Amiga Never Died?
What if Commodore had never gone bankrupt and Amiga development had never stopped?
mikeMike 3 days ago0 Comments
*Mike · September 15, 2026*
**Tags:** Project Ceylon, Workshop, Microkernel, Systems Engineering, Roadmap
A long day of audit closure and microkernel migration work froze a reproducible Ceylon baseline and advanced the new foundation to the B0 validation gate.
Today turned into a much longer development tranche than I expected. What started as preparation for an underlying system update ended up consuming most of the afternoon and evening, but we finished the day in a very good place.
The first major milestone was freezing a new known-good Ceylon baseline. That means we now have a version of the system that is not simply working, but documented, reproducible, independently reviewed, tested under multiple execution environments, and backed by a performance baseline we can use for future comparisons.
That distinction is important. When you are building an operating system, especially one intended to grow into a serious multimedia and workstation platform, eventually "it boots" is no longer a useful definition of success. You need to know exactly what code produced the system, whether another clean build produces the same functional result, whether failure paths behave correctly, and whether future changes make the system better or worse.
## Why We Are Updating the Microkernel
With that baseline safely preserved, we moved on to the next major step: updating the microkernel foundation underneath Ceylon. This is not an update for the sake of having a newer version number.
Recent architectural research into memory management, shared memory, device access, DMA, process isolation, execution contexts, and high-performance data paths exposed opportunities that make more sense if we modernize the underlying kernel environment first.
As the project grows, memory cannot just be thought of as RAM an application gets. We need increasingly sophisticated control over which subsystem owns a region, which processes may map it, which devices may access it directly, when memory is pinned or reclaimed, how stale mappings are rejected, how shared data moves without unnecessary copying, and how those rules remain enforceable when something crashes or restarts.
Those are foundational operating-system problems, and they directly affect performance. If we get the architecture right, Ceylon can eventually move large amounts of graphics, audio, storage, and media data through the system without constantly copying it from one private buffer to another.
## Research Before Implementation
A lot of the recent work has actually been research rather than coding. I have been looking closely at how mature operating systems and multimedia platforms solve problems such as shared buffers, registered memory, DMA ownership, resource lifetime, high-performance queues, and hardware isolation.
The goal is not to copy another operating system. It is to understand which ideas have proven durable, why they work, where they fail, and which lessons make sense for Ceylon. That research has already generated several promising architectural directions for later development.
But before implementing those ideas, it became clear that updating the microkernel now would give us a much better foundation to build them on. So that became today's job.
## A Longer Tranche Than Expected
Updating something this far down in the system affects considerably more than changing a dependency number. Low-level memory configuration changed. Device isolation changed. Interrupt handling needed to be reviewed. Runtime and linker assumptions had to be checked. Hardware-access paths needed to be validated.
Because we had just established a clean baseline, I was not willing to make enough changes to get the machine to boot and call it finished. The updated system had to pass the same tests as the previous baseline. By the end of the night, it did.
The new candidate builds successfully, boots under both of our primary virtualized execution modes, reaches the authentication system, display subsystem, and NuGUI normally, and passes the existing workspace, documentation, clock, synchronization, and performance-test infrastructure. Preliminary performance results show no obvious regression from the update. That is encouraging, but it is not enough for promotion.
## Next: Try to Break It
The updated microkernel candidate is now frozen for the next phase. The old baseline remains the official governing version of Ceylon.
Next comes deeper validation. Instead of simply asking whether the system runs, we will deliberately test the new isolation and hardware-access behavior: devices must not reach memory they were not authorized to access, interrupts must remain correctly isolated, floating-point state must not leak between execution contexts, and the underlying runtime must continue behaving correctly under failure and stress.
Only after those checks pass will we move into a more formal performance and assurance comparison. Only after that will the new foundation replace the old one.
That may sound conservative, but this is exactly the point in the project where conservative engineering pays off. Ceylon is becoming complicated enough that future progress depends on having foundations we can trust. Today was a long afternoon and evening spent strengthening one of those foundations. Not flashy. But very important.
*Originally published on The Weekend Report: https://theweekendersproject.com/report/ceylon-development-log-september-14-2026*
