Project Overview & Objectives
This project is a low-cost, workshop-built cricket bowling machine designed primarily for children practicing with lightweight 65 mm plastic cricket balls.
Built using readily available materials, the working prototype provides consistent ball delivery and incorporates a custom mechanical sequencing system for reliable single-ball feeding.
Beyond standard batting practice, real-world field testing revealed two additional training modes: slip-catching practice and high-catching practice, achieved by tilting the frame upward.
The machine is now considered a completed prototype and will remain unaltered for a 6-to-12-month period to observe its long-term reliability.
Core Requirements
Technical Architecture & Working Principle
The propulsion mechanism uses two high-speed wheels spinning in opposite directions. Driven independently by dedicated RS775 DC motors, the friction generated compresses the ball through a set gap, accelerating it forward. Adjusting individual motor voltages via a 555-timer PWM setup controls ball speed and delivery dynamics.
Component Checklist:
Mechanical Evolution & Lessons Learned
1. The Dynamic Wheel Gap Failure (Slow-Motion Video Insight)
2. Solving High-RPM Wheel Vibration
Severe system noise and structural oscillation threatened early testing. This engineering bottleneck was solved through a systematic overhaul:
Automatic Single-Ball Feeding Sequence
The mechanical control stack relies on gravity and mechanical timing rather than a microprocessor.
Vertical Gravity Chute
Horizontal PVC Barrel
          ←  1¾" Wide Piston
             Blocks Upper Chute
Solenoid Retracts Pin
Ball Pushed into Propulsion Wheels
The Integrated Piston & Gate
The sliding PVC piston is sized with a 1–2mm internal clearance to guarantee low friction. Its 1¾-inch structural width allows it to act as its own mechanical gate valve. When pushed forward, the piston body physically blocks the bottom of the vertical gravity chute, holding back subsequent balls until the current ball is launched and the piston retracts fully to its home position.
The 6-Phase Delivery Loop:
  1. Home Position: Piston is fully retracted, leaving the chute clear. One ball drops into the barrel; the deenergized solenoid pin physically blocks it from rolling forward.
  2. Cycle Trigger: The 30 RPM geared motor turns, rotating the crank disc.
  3. Gate Release: The 12V solenoid energizes, instantly retracting the blocking pin.
  4. Feed Stroke: The connecting link translates rotary motion to linear piston travel, driving the ball into the delivery channel while blocking the next ball in the chute.
  5. Launch Zone: The ball passes the PVC guide, hits the high-speed wheel nip, and fires downrange.
  6. Cycle Reset: The crank pulls the piston back, the solenoid drops the and the blocking pin comes up, the next ball reloads, and a home-position micro switch halts the motor until the next start pulse.
First ball ready to be launched
1st ball launched and 2nd ball blocked
2nd ball allowed in the barrel
Performance Observations & Field Trials
Continuous testing across single-session runs of 48 balls (8 overs) and 60 balls (10 overs) yielded crucial data points:
Speed Tracking Analysis Limits
Attempts to log exact ball exit velocity using a standard smartphone camera (including high frame-rate and slow-motion video) proved inconclusive. Over short 1-meter tracking baselines, the ball moved too fast for the frame rate. Over a 5-meter window, travel clocked at 12–14 frames at 30 FPS. However, because lightweight plastic balls loses significant velocity during flight and frame-boundary timing is highly uncertain, this calculated average does not capture true muzzle speed. Precise speed quantification requires a dedicated optical gate or radar array.
Long-Term Plan & Next-Gen Concepts (ESP32)
The present system is frozen as a completed prototype for a 6-to-12-month evaluation phase to verify part durability, battery limits, and mechanical fatigue.
Future iterations will explore a separate, advanced machine using these experimental insights:
  1. Enlarged Wheel Diameters: Shifting to larger wheels to secure identical linear ball velocities at lower motor RPM, minimizing structural fatigue.
  2. Metal Monocoque Chassis: Trading the wooden frame for a rigid 3mm or 4mm steel/aluminum base plate.
  3. Contoured Wheel Crowns: Machining an optimized profile into the wheel treads to cup the sphere, boosting surface contact and energy transfer.
  4. ESP32 Digital Control: Upgrading the control deck to an ESP32 running MicroPython. This will allow independent digital control of each wheel's speed (to easily bowl curveballs, spin, and swing variations), automated servo-driven tilt adjustments, random pacing, and programmable practice sequences.
Project files: Schematics, source files and other supporting project files are available in the GitHub repository linked in the External Links section above.
