THE PRIORITY ORDER
First: low power consumption.
Second: speed of work output.
Byproducts like desalination: real and valuable, separate from the
primary design goals.
Earth first. Man second.
Every design decision in this system follows that order. Not as a
slogan -- as an engineering constraint that shaped every circuit.
THE PROBLEM BEING SOLVED
The AI industry's current trajectory: build $5B-$15B nuclear power plants
to run inference on architectures that generate most of their heat before
doing any useful computation. Clock trees. Decode trees. Memory bank
access. Bus traversal. All of it generating heat on every token lookup,
every millisecond, at gigahertz speeds.
The structural response: eliminate the overhead architecturally, generate
the remaining power from tidal flow, recover the motor energy that would
otherwise dissipate as heat, and cool the facility with the same motor
technology that generates the power.
None of these are optimizations. They are structural replacements.
LAYER 1: POWER GENERATION
THE TIDAL PULSE TOWER
~290kW per tower. LCOE ~0.123 cents/kWh. Build cost ~$153K. Firm floor
145kW. Net wind value $1.18M/yr per tower. Fuel: zero. Emissions: zero.
The tower uses an annular vortex design with dual-Pelton wheels on a
common shaft. The center tube performs three functions simultaneously:
air highway (air rises freely while water falls in annular), structural
spine (fliprole of hourglass), and vortex core (the Rankine solid body).
18+ innovations. All public domain.
THE TRIPLE DRIVE PMM/PMG COMBO
The Triple Drive version of the Permanent Magnet Motor/Generator compound
runs at a 4:1 wheel ratio (inner 9, outer 36). Four points push and pull
simultaneously. At any moment when one cog on any single rotor is in phase,
the electromagnetic pass-and-collect cycle captures BEMF.
The single PMM runs at a 2:1 ratio. The Triple Drive compounds this to 4:1
-- four active push/pull points versus one, with the same structural BEMF
recovery available at each phase crossing.
The 38.17 degree extraction angle: peak EMF does not occur at dead center
alignment. It occurs at arcsin(phi-1) = arcsin(0.618) = 38.17 degrees
before it. This has been confirmed in combustion engine ignition timing
for 140 years. Applied here to generator design, it eliminates the peak
EMF vs peak cog fighting that standard generators accept as unavoidable.
THE HOURGLASS GENERATOR
Dual-Pelton annular vortex. Air and water fully separated throughout
the cycle -- no competition, no alignment. PMG stays energized.
Continuous output with zero dead zones.
PMM COOLING FANS
The same PMM design that generates facility power also drives the cooling
fans. Precision, efficient, and subject to the same BEMF recovery as
the generators. The Adaptive Switching principle (Fibonacci-integer
switching frequencies, see below) eliminates beat frequency heat from
the fan motors as well as the generators.
LAYER 2: POWER DISTRIBUTION AND STORAGE
PHWM / SPLIT POSITIVE / PASS THE BUCK TOPOLOGY
Pulse Height Width Modulation with Split Positive multi-stack architecture.
The boost and motor drive circuits float between positive rails at all times.
Ground contact exists only at battery stacks, controls, and the BEMF
collapse diode -- never in the motor drive path during active phases.
Four-phase energy cycle per pulse:
Phase 1 Boost: source stack pulses through coil, sinking to lower
storage stack as boost reference. Capacitor charges above supply voltage.
Phase 2 Drive: elevated pulse releases through motor coil. Mechanical
work done. Receiving battery stack charges simultaneously.
Phase 3 BEMF collapse: coil pulse ends. Back-EMF reverses. Diode provides momentary directional ground contact after EMF polarity reversal — the reversed wave forward-biases the diode passively. Same diode blocks the positive wave.
Collapse energy files into the receiving stack.
Phase 4 Buck release: charged stack releases to opposite stack.
Battery balancing emerges from sequential energy passing without any
dedicated balancing circuit. Nothing goes to ground except controls and
the BEMF collapse diode.
BEMF DUAL-DIODE RECOVERY: 80-87% OF ELECTROMAGNETIC EXPENDITURE
The Triple Drive is a hybrid motor -- part PMM, part BLDC. This
distinction is critical to understanding where the 80-87% figure applies.
The permanent magnets carry the primary torque load. They do the main
work. Once rotating, the PM torque output is the dominant energy in
the system.
The electromagnetics do a fundamentally different and smaller job:
they support rotation through one cog at a time, making each cog
transition electromagnetically null. With four push/pull points always
active, the electromagnetic assist is a precisely targeted, relatively
small expenditure compared to the PM torque output.
The 80-87% BEMF recovery applies to that electromagnetic expenditure --
not to total system output. The dual diode recovery circuit operates
fast enough to capture 80-87% of the energy spent on each
electromagnetic cog assist before it dissipates.
The net picture:
PM torque: carries the main load, primary energy source
Electromagnetic assist: small expenditure, precisely timed
BEMF recovery: returns 80-87% of that small expenditure per cycle
PMG output: substantial power generation from the PM torque
This makes the electromagnetic running cost nearly negligible.
The permanent magnets do the heavy work. The electromagnetics steer.
The BEMF circuit recovers most of what steering costs.
Energy that conventional BLDC topologies route to ground becomes
a charging current for the battery stack. The waste is structural in
conventional designs. The recovery is structural here.
ADAPTIVE SWITCHING -- FIBONACCI-INTEGER FREQUENCY
Standard motor controllers use fixed switching frequencies. At nearly
every RPM, a non-zero beat residual exists between switching frequency
and electrical frequency -- partial commutation cycles that cannot
complete. These become heat. Every RPM. Every revolution.
Fix: select switching frequency as a Fibonacci-integer multiple of
electrical frequency. Beat frequency = 0 by definition. Heat from this
source: gone. Applied to every motor in the facility -- generators,
cooling fans, servo drives. Zero hardware changes from standard designs.
DUAL-SIDED RIPPLE FILTER
Cross-phase capacitance multiplier with collector-emitter steering diode.
Phase A conducts and simultaneously pre-charges Phase B's capacitor.
When the AC wave crosses zero, Phase B takes over with full energy
already stored. No sag. No 120Hz ripple. No iron chokes required.
The AC wave timing IS the control mechanism.
LAYER 3: AI COMPUTE -- COLD, FAST, CLOCKLESS
THE FLAT-LINE POWER LAW
In any N-way DTL one-hot cell: exactly one transistor conducts. All
others draw absolute zero current. Whether N is 3 (ternary weight cell)
or 32,768 (full LLM token vocabulary), idle power is constant. Power
consumption does not scale with position count.
This is why the compute layer runs cold: not because each transistor
uses less power, but because only one is ever conducting. The other
32,767 positions in a token vocabulary table draw nothing.
THE TERNARY WEIGHT CELL (Tri.Flop)
One transistor per neural network weight. Stores {-1, 0, +1} -- exactly
the quantization used in ternary neural networks including BitNet b1.58.
No binary encoding. No decode. Position is value. 30 years production proof
in a tube amplifier chassis. Compatible with the optical bus below.
THE TOKEN VOCABULARY ACCELERATOR
A modern LLM vocabulary of 32,768 tokens requires 93 routing lines in a
symmetric 3-level 32x32x32 hierarchy. Three electric field propagation
steps to identify any token. No decode tree. No clock. No memory bank
access. No bus traversal.
Compare to conventional: address decode tree switching, clock tree
(~35% of chip power), memory bank access, sense amplifier firing --
all of it, on every token, millions of times per second.
General law: k levels x (N-1) = total routing lines.
k=3, N=32: 93 lines, 3 transistors, 32,768 tokens
k=5, N=8: 35 lines, 5 transistors, 32,768 tokens
The designer chooses k based on routing budget. More levels = fewer
lines = smaller nodes = faster propagation = less parasitic capacitance.
For AI facilities at sustained high utilization, idle power is not
the relevant metric. Per-token-lookup energy during continuous operation
is -- and on that metric this architecture wins at every k.
THE 3D STACKED POSITIONAL CORE -- LAYOUT FREEDOM
Because exactly one transistor conducts per cell regardless of stack
depth, the thermal density is constant at any volume. 100 layers
generates the same heat as 1 layer. There is no thermal wall between
stacked layers.
This eliminates the constraint that forces conventional chip design to
organize around cooling infrastructure. Layout decisions follow
mathematical routing efficiency -- shortest path, not nearest cooling fin.
Three-layer physical architecture:
Layer 1: Asynchronous Hold Core -- one transistor saturated, runs cold
Layer 2: Topological Diode-Steering Matrix -- Radio Button logic
Layer 3: Optical Coupling and Waveguide Stratum -- LED emitters into
silicon-on-insulator waveguides
For the 32x32x32 token vocabulary, each 32-way cell is a tight planar
ring. Three tiers stacked vertically. Level 1 (root category) at the
base, Level 2 (subgroup) in the middle, Level 3 (specific token) at top.
The hardware IS the linguistic hierarchy in physical space. Wiring
between tiers is vertical TSVs of micrometer length.
THE OPTICAL BUS (Flip-Flopticoupler)
The LED in the base path is already there -- it is the series blocking
diode. Choosing LED instead of 1N914 adds zero components. The same
current that flows through the LED as a diode also fires photons onto
the optical bus.
One LED. Three simultaneous functions: series blocking diode, state
indicator, optical bus emitter.
Optical bus properties: zero EMI cross-talk between channels (light
beams do not interfere), galvanic isolation between cells (no copper
connection between sender and receiver), light-speed transmission,
transparent optical vias between 3D stack layers instead of copper TSVs.
Phantom State: when no transistor is active, the optical bus is dark.
Darkness is the default state. Zero energy to maintain. Zero to detect.
LAYER 4: THE COMPLETE ENERGY FLOW
Tidal Tower generates power continuously from tidal flow.
PHWM multi-stack manages storage and distribution. Nothing goes to
ground wasted. Battery balancing is emergent from the sequential
energy passing topology.
AI compute runs on DTL one-hot architecture. No clock tree. No decode
tree. No memory bank access overhead. Per-token energy: three short
electric field steps. That is all.
PMM fans handle residual cooling. Adaptive Switching eliminates beat
frequency heat from the fans. BEMF recovery returns 80-87% of fan
motor energy to storage per cycle.
Dual-sided ripple filter manages power quality throughout the facility
without iron chokes or large capacitors.
Net result: a facility where the power consumed is proportional to
the actual computation performed, not to the infrastructure overhead
that conventional architectures require to operate.
THE DESALINATION BYPRODUCT
Tidal infrastructure operates at the water interface. Pressure
differentials and flow dynamics inherent to the Tidal Pulse Tower
operation create conditions suitable for low-energy reverse osmosis
or other desalination processes without additional energy input beyond
what the tower already generates.
This is not the primary design goal. It is a byproduct of building at
the tidal interface. For island nations without resources to burn,
it may be the more valuable output. Fresh water from tidal flow,
powered by the same tower that runs the compute infrastructure.
WHO THIS IS FOR
Island nations without large power infrastructure: the Tidal Tower alone
is viable without the full AI compute stack. Power generation, fresh water,
community scale.
AI facilities at any scale: even without on-site tidal generation, the
DTL compute architecture and PHWM power management reduce consumption
enough to operate from partial grid connection without the current
thermal crisis.
Grid-light applications: the system can supplement rather than replace
grid power. When tidal output exceeds demand, feed back. When below,
draw minimally. The PHWM multi-stack manages the transition.
Large-scale AI infrastructure: the full system -- Tidal Tower array,
PHWM storage, DTL cold compute, BEMF recovery, optical bus -- eliminates
external power dependency entirely for sustained operation.
PUBLIC DOMAIN DECLARATION
Alan Cyr (Wolf13), CYR Technologies, Chicago, releases all of the
following to public domain:
Tidal Pulse Tower -- all 18+ innovations
Triple Drive PMM/PMG Combo and single PMM/PMG Combo
Hourglass Generator
Cog Reduction principle
DTL Hold Circuit and all N-way variations
Tri.Flop ternary weight cell
One-Hot ASCII storage
k-Level Token Vocabulary Accelerator
3D Stacked Positional Core architecture
Flip-Flopticoupler optical bus
Adaptive Switching for all motor and generator applications
Dual-Sided Ripple Filter
Complete facility integration architecture described in this post
The PHWM / Split Positive / Pass the Buck topology is not included
in this public domain release and remains reserved.
Free to use. Free to build. Free to sell. Free to patent improvements.
No license. No royalty. No attribution required.
If it saves the earth, that is enough.
RELATED POSTS (Hackaday, 2026, all public domain)
Tri.Flop -- A 30-Year-Old Guitar Amp Circuit That Stores Neural Network Weights
One LOW in 128 HIGH Lines -- Single Transistor Holds Full ASCII Character
The LED Was Already In The Schematic -- Optical Bus and Series Diode Scaling
Build What You Need -- Scalable Structural Token Lookup for AI Inference
Tidal Pulse Tower -- Green Powered Challenge entry
Wolf13 / Alan Cyr * CYR Technologies * Chicago * September 2026
Alan Cyr
