Solarium provides interfaces to provide a processor (jib), assembler (jasm), and basic high-level language (c/buoy) around a hypothetical 32-bit processor that provides a simple RISC-like ISA. It is designed as an homage to computers of yore, providing a playground to experiment and tinker with a hypothetical retro computer, and get a better understanding for how computers work at a lower level.
The whole stack is designed to be easy to understand, from the instruction set, assembler, language. The virtual machine is written in Rust, using egui as the ui framework, with some C/C++ for the FUSE driver for integration of the custom filesystem into modern environments.
The CB/OS operating system is written on this, with simple primitives for memory management, threading, and filesystem operations with a custom FAT-like operating system called CBFS.
See the links, which include an online demo and download links for the virtual machine, FUSE driver, and compiler.
Files
isa v0.10.7.pdf
Documentation for v0.10.7 (2026-09-19)
Adobe Portable Document Format -
441.94 kB -
09/24/2026 at 02:16
This is the first "featured" version of the computer. Previous versions had read support for the filesystem, a linker for applications to pull in symbols from the OS, and more. This version brings in basic write support, allowing files and folders to be created, entries to be moved around, directories to be copied, and more.
This is where the system starts to feel "real," where basic OS tasks can be accomplished and the OS feels a bit less toy-like.
There is still a long way to go, but this is now one step closer to a usable system.
Some future tasks include creating a text editor and porting a compiler over, so that the system can be fully self-hosting, but both those will take a little more time to come to fruition. For now, I'm pretty happy with where things are at with the system.
