RunCPM Prompt Support
A project log for Retro Gaming Console on RV32IM CPU (DE0 Nano FPGA)
A 32-game console on a custom dual-issue RV32IM CPU and a DE0-Nano FPGA, running DOOM, CP/M 2.2 and Chip-8 bare-metal
mjagadeesh97M_Jagadeesh97 • 2 hours ago•0 Comments
The RunCPM prompt with DIR, ASM, DDT and MBASIC.
The console runs original CP/M 2.2 software, including Microsoft BASIC-80, through a port of RunCPM to bare metal. The Z80 decoder supplies the register file, a 64 KB virtual address space, and the zero page vectors at 0x0000 for warm boot and 0x0005 for the BDOS entry.
Standard RunCPM expects a hosted POSIX filesystem to expose its virtual drives. There is none here, so the disk is packed ahead of time: a script scans a directory, converts filenames into 11-byte CP/M form with 8.3 space padding, and writes the disk blob that goes into the asset container. The BDOS translation layer traps the calls and routes them:
One bug is worth recording in full, because its symptom was a hang rather than an error.
Files larger than 16 KB are split across CP/M extents. The record offset was being computed from the record field alone, so at record 128 the address wrapped back to the start of the file and the read looped forever. The correct linear offset uses both fields:
offset = ((fcb->ex * 128) + fcb->cr) * 128
MBASIC.COM is 24 KB, so this hit on the first program that mattered. A naive implementation does not crash; it spins, which costs an afternoon before the penny drops.
ESC during blocking console input needed its own path for the same reason the launcher did. The character input loop polls the hardware key register every 22 ms and unwinds to the launcher on keycode 27, so a CP/M program that blocks on input can still be exited with one key, and the console does not have to be rebooted to escape a text adventure.
Speed: at 50 MHz with SDRAM access latencies, the Z80 interpreter runs at roughly a 2 to 4 MHz equivalent, which is the range of the machines that ran this software originally. Star Trek, Hamurabi and Lunar Lander are period-appropriate at that speed rather than merely tolerable.
Star Trek (1971)
Hamurabi (1968)
Hunt the Wumpus
Porting this was the most retrocomputing part of the project so far: original 8080-era binaries, unmodified, running on a RISC-V core I designed, with the disk image packed at build time and the console rendered into a 64x32 framebuffer.
