Hackaday.io Hackaday.io
Sign up Log in
Raspberry Pi 5 NAS Build (OMV + Tailscale)
Global Access to Private Cloud Data with Pi 5 Nas Build
davchi15davchi15
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
0
1
0
Team (1)
  • davchi15davchi15
Join this project's team
ongoing project
This project was created on 09/21/2026 and last updated a day ago.
Description
Hey everyone, I wanted to share my intro to homelabbing project. I finally decided to go through with building a dedicated private cloud that I actually own.
The Hardware: Raspberry Pi 5, a 500GB WD Green SSD, and a 3D-printed open-frame chassis to keep the airflow moving.
The Software: OpenMediaVault handles the NAS backend, and I set up Tailscale so I can securely access my files from my phone or laptop anywhere in the world without exposing ports.
I put together a full video documenting the build process and software setup for anyone looking to do something similar
Details
Log In/Sign up to comment
Sign up with Github
OR
This Raspberry Pi HAT allows to connect industrial sensors and other devices that ar compatible with IO-Link to Raspberry Pi
Project Owner Contributor
IOL HAT - Industrial Sensor Connectivity for RPi
andreas-lauAndreas Lau
An open source Raspberry Pi Hat template to help developers get there Hats built
Raspberry Pi Hat Template
julienjulien
data.sparkfun.com is an open source IoT platform. This is about pushing data from Raspberry Pi to data.sparkfun.com using Python.
Raspberry Pi : push data to data.sparkfun.com
alfredcAlfredC
Run a simple Python script that will collect system information from a Raspberry Pi and send it to a cloud platform dashboard.
Pi Health Dashboard
initial-stateInitial State
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Raspberry Pi 5 NAS Build (OMV + Tailscale)", please tell us the reason.
Send message
Remove Member
