Assembling the ACEBOTT 4-DOF Robot Arm
A project log for EWNA Hackathon Team 1 (Team Marker My Words)
A 4-DOF arm on an Arduino UNO Q that sees a hand-drawn line, picks up a marker, traces it, dodges obstacles live, and puts the marker back.
shubhan-mitalShubhan Mital 18 hours ago0 Comments
Before we could teach the arm to see, trace or dodge anything, we had to build it. The ACEBOTT QD022 kit arrives as a bag of laser-cut acrylic panels, four MG90 servos and a lot of small screws and nuts. A big chunk of our first day was spent on turning the components from that kit into a working arm.
What we followed
We used ACEBOTT's official assembly tutorial for the QD022.
 It's beginner-friendly with each step showing exactly which panel and which screws to use. If you're building one yourself, we'd recommend following it step by step.
What we learned (tips for beginners)
Result
By the end of this step we had a fully assembled arm that moved on all four joints when tested with the kit's joystick module.
