Final Steps
A project log for EWNA Hackathon Team Trash
Sustainability
isaac-meyerIsaac Meyer 6 hours ago0 Comments
1:30PM
We are reaching the end of the allocated time we have for this project. We have chosen a model and tuned our outputs to vary a bit depending on the parameters we are reading from the image so we can get a slightly more accurate reading/prediction of the trash we are sorting.
We have had Ruize and Isaac working on the model's vision and determination of class of trash that we are presenting it with. They also worked on getting the python code files to successfully launch the camera and call on the bridge functions to start the communication channel between the MPU and MCU.
Cory and Matthew worked on the hardware side of things by setting up the physical connection between the board and external components as well as setting up our conveyer belt and camera to get the best angle we could find to look over the trash we were putting onto the display.
Currently we are done with all the individual components of the project and it is just the connection of the pieces that we are currently working on.
