TekView Micro Driver MD1 is an ultra-compact power and control board for DC motors and linear actuators, built to the Seeed Studio XIAO footprint. Plug in a XIAO ESP32-C6, C3, S3 or nRF52840 and you get wireless control (Wi-Fi, BLE, Matter/Thread) with no extra wiring.
Key features:
Up to 36V input, 3A continuous (4A short-term), with fuse and TVS input protection
Digital current sensing and fault diagnostics over SPI
On-board 5V supply for the microcontroller, powered straight from the motor battery
Manual bypass port for classic up/down buttons, so the actuator still works if the wireless side fails, which matters for medical and industrial furniture
Reserved input for a Hall sensor for speed and position feedback
Via-array thermal design, no external heatsink needed
Target uses are smart and medical furniture, robotics, and IoT projects where you want wireless actuator control in a very small space. Firmware is left open so you can write it for your own application.
