The GlitchCaster maintains the same capability and balance of safety and cost as the PicoEMP while addressing several concerns:
Mounting: Specifically designed to be mounted on 3D printers or CNC machines for cheap and precise XYZ staging rather than to be operated by hand.
Coil Compatibility: Supports SMA and Through-Hole style probe coils
Flexibility of Control: Allows for the use of controllers other than RP2040s while maintaining backwards compatibility with controllers running firmware for similar remixes and predecessors.
