The max current draw stayed at around ~50mA when the bluetooth module is connected. 0.7Wh / (5V *.05A) = 2.8h. Assuming the power boost module is about 90% efficient, it equals about 2.52h of battery life per battery. The glasses can also be powered over USB using a portable battery pack.
Tony E. Nazzal
