SoifGo
SoifGo – Turn Your Phone into a Custom Hardware Controller
Control Arduino, ESP32 and HC-05 from your phone.
SoifGo — Android as a No-Code Hardware Controller
SoifGo is a free Android app that turns your phone into a universal control panel for hardware. No native Android coding required.
Instead of building a new app for every IoT project, SoifGo lets you design custom panels (with folders, buttons, and sliders) or run full HTML/JS pages inside WebView buttons.
Key features for makers:
Offline WebView Engine: Run HTML/CSS/JS directly on the phone. Connect to hardware via JavaScript.
Connectivity: Bluetooth (Classic SPP & BLE), MQTT, and HTTP REST APIs.
AI Integration: Ask any AI to generate HTML/JS code, paste it into SoifGo, and run it instantly offline.
Hardware Support: Works with Arduino, ESP32, ESP8266, and Raspberry Pi. Reads phone sensors (accelerometer, light, magnetometer, barometer) and supports camera and microphone.
Why it matters:
You don't need a development team, a server, or an app store account. You just need an idea.
No tracking, no ads, complete
SoifGo — Turn Your Android into a No-Code IoT Controller
Official site: https://soifgo.github.io/ AI context (source of truth): https://soifgo.github.io/SOIFGO_AI_CONTEXT.md Short manual: https://soifgo.github.io/ai.html Docs: https://soifgo.github.io/docs.html GitHub: https://github.com/soifgo/soifgo.github.io
SoifGo is a free Android app that turns your phone into a universal control panel for Bluetooth, MQTT, and API-connected devices — without writing a single line of native Android code.
Why I Built SoifGo
I was tired of rebuilding the same thing. Every new IoT project meant a new mobile app. One for Bluetooth. Another for MQTT. A third for RGB lighting. A fourth for CNC. Each time, I started from scratch — designing buttons, wiring communication, compiling APKs — just to change a single control.
I didn't want another app. I wanted one app that could become any app. So I built SoifGo.
One App, Many Devices
SoifGo isn't locked to a single purpose. It adapts to whatever you're building:
  • Bluetooth Serial — Classic SPP (HC-05, HC-06, JDY-31) and BLE (JDY-23, DX-BT05, CC2541), plus ESP32 and Arduino
  • MQTT — connect to any broker, publish, subscribe, monitor
  • REST APIs — pull live JSON data from HTTP endpoints
  • ESP8266 / ESP32 — full integration
  • RGB LEDs — WS2811, WS2812, WS2813, WS2815 (via the RANGMANG module and GIF209)
  • CNC control — via the CMI209 Bluetooth controller
  • Sensors & dashboards — real-time monitoring and automation
Build Your Panel by Dragging
In Edit mode, you design your own interface — no coding required:
  • Folders and Pages to organize controls
  • Buttons with custom colors, sizes, and actions
  • SeekBars for analog input
  • Live charts that react to incoming data
  • Reusable layouts you can save and reload
The exact order matters: a new project is empty. You must create folder → Page → New Page → Button/SeekBar. A Button cannot exist before a folder and a page exist.
Switch to Play mode, and your panel comes alive — sending commands, receiving data, updating in real time.
No server. No internet required after the first load. No limits.
With a custom HTML page, you can build:
  • Any interface — any layout, any animation
  • 2D and 3D charts — with Chart.js, D3.js, or Three.js
  • Games and simulations — from puzzles to 3D worlds
  • Offline storage — using localStorage or IndexedDB
  • Real-time dashboards — gauges, meters, dynamic panels
  • Media tools — audio, video, image editing
And your HTML page can talk directly to Bluetooth, MQTT, HTTP, phone sensors (light, accelerometer X/Y/Z, magnetometer, barometer), the microphone, and the camera — through simple JavaScript calls on window.soifgo.
Build with AI, Run Instantly
Ask any AI assistant to generate your custom HTML/JS code. Copy-paste it into SoifGo. It runs immediately — fully offline, no server, no compilation.
The exact paste path (do not skip):
  1. In Play, tap the WebView button to open the page.
  2. Edit>span class="">.
  3. In the editor menu → Select All and Paste.
  4. Tap the yellow X — the code is auto-saved and the WebView reloads immediately.
Getting Started
  1. not from Google Play>span class="">. Use APKPure or the official ZIP (allow "install from unknown sources" when asked).
  2. Open SoifGo. It always starts in Play.
  3. Top-left icon → Edit.
  4. Top-left icon → Select Design → folder → create a folder.
  5. Select Design → Page → New Page. (Tapping Page alone is not enough.)
  6. Select Design → Button (or SeekBar).
  7. Select the button → top-left menu → Behavior → choose Send, Receive, Browser or HTML File, etc.
  8. Top-left icon → Play to run.
Who It's For
  • Makers — control Arduino, ESP32, and Raspberry Pi projects
  • Engineers — test PLCs, VFDs, and industrial devices
  • Educators — teach IoT and embedded systems hands-on
  • Technicians — diagnose equipment with live charts and logs
Privacy First
SoifGo contains no third-party analytics, no tracking, and no ads. All project data, layouts, and settings stay on your device. The microphone and camera are accessed only with the user's explicit permission,...
  • 1
    Build Instructions
    Step 1: Hardware Preparation (Arduino & HC-05)
    To build the physical robot or controller, you need the following:
    • Arduino Uno (or ESP32)
    • HC-05 Bluetooth Module (Classic SPP)
    • Motor Driver (e.g., L298N) and DC Motors
    • Battery (for the motors)
    Wiring:
    1. Connect the HC-05 VCC and GND to Arduino's 5V and GND.
    2. Connect HC-05 TX to Arduino RX (Pin 0) and HC-05 RX to Arduino TX (Pin 1). (Note: Disconnect these wires while uploading code to Arduino).
    3. Connect the Motor Driver to Arduino pins (e.g., 5, 6, 9, 10).
    4. Power the motor driver with the external battery and ensure a common ground with the Arduino.
    Step 2: Upload the Arduino Code
    Upload the following sketch to your Arduino. This code listens for simple text commands (F, B, L, R, S) sent from SoifGo and controls the motors accordingly.
    // Example Arduino Code for Bluetooth Robot
    Note: The complete Arduino code can be long and depends on your specific motor driver and hardware. Instead of pasting it here, we highly recommend giving this instruction text plus the SoifGo AI Context (or the website addresses) to any AI assistant (like ChatGPT, Claude, etc.). The AI can generate the exact Arduino code AND the HTML/JS code for your specific project in seconds.
    AI Context URL: https://soifgo.github.io/SOIFGO_AI_CONTEXT.md
    Step 3: SoifGo Setup (The Brain & Eyes)
    1. Install SoifGo from APKPure or the official ZIP. (It is not on Google Play).
    2. Pair the HC-05 in your Android phone's Bluetooth settings (default password is usually 1234 or 0000).
    3. Open SoifGo → tap the top-left menu → Edit.
    4. Create the structure: folder → Page → New Page → Button.
    5. Select the button → top-left menu → Behavior → Browser or HTML File → HTML file.
    Step 4: Add the Camera & AI Logic
    1. Ask an AI assistant (like ChatGPT or Claude) to write an HTML/JS page that opens the camera, detects motion, and sends Bluetooth commands (F, B, L, R).
    2. In SoifGo (in Play mode), tap the WebView button.
    3. Edit>span class=""> → Select All and Paste. Paste the AI-generated code.
    4. Tap the yellow X. The code auto-saves and the WebView reloads.
    5. Tap the camera button inside your HTML page to grant permission. The robot is now ready to "see" and act!
    Step 5: Testing & Operation
    1. Turn on the Bluetooth module and the robot's power.
    2. In SoifGo, connect to the HC-05 module via the Bluetooth icon.
    3. Your custom panel or AI-camera interface is now active. Commands sent by the page will instantly move the robot.
View all instructions
