Finding the Power Button (A Multimeter Trap!)
A project log for Rożen (The Ryzen Mini-PC)
Turning a salvaged laptop motherboard into a portable mini-PC
tomek-szczsnyTomek Szczęsny • an hour ago•0 Comments
Since I plan to build a custom wooden case and mount the computer under my desk, I needed a way to turn it on without the original laptop keyboard. I had to reverse-engineer the 26-pin keyboard ribbon cable to find the power button traces.
This became an interesting electronics riddle.
I switched my multimeter to Diode Test Mode with a fast screen refresh rate. This mode easily detects the voltage drop across a 150-Ohm resistance. Using this trick, I successfully located the power trigger on pins 1 and 2. With help of a breakout board, I will emulate this key with a larger button mounted on the case at the later stage of the project.
In the meantime, I have located a motherboard test point that acts as a power switch when shorted to GND, which I currently use for test launches.
