Version 1.7 of OFFgrid-SDR is out.
It’s still the same idea: a complete RTL-SDR receiver in a single HTML file that runs in the browser, with no installation, no drivers on most systems, and no internet. This release is mostly about making the receiver work things out for you, and making it more dependable on real hardware.
AUTO got much smarter
AUTO listens to a signal for a couple of seconds, works out what it is, and switches to the right mode. In 1.7 it handles SSB properly. It finds the whole voice wherever the dial sits on it, picks LSB or USB from where the speech energy sits, and then tunes to the suppressed carrier to within a few hertz. It does that by lining up the harmonics of the speaker’s voice: voiced speech is a comb of harmonics at whole multiples of the pitch, and the comb only lines up at the true carrier. Clicking an SSB signal on the waterfall does the same fine-tuning by itself.
It also now recognises FT8, FT4, ACARS, PSK63 and PSK125. It no longer mistakes fading AM for Morse, an off-tune voice for PSK, or fast Morse for Hellschreiber. Each of those fixes came from a diagnostics log of a real signal it got wrong.
FT8 and FT4, still completely offline
There’s a new FT4 decoder alongside FT8, and the decode list now shows each station’s country and its distance and bearing from you. None of that needs the internet:
- Countries come from a table of callsign prefixes built into the file, covering 269 countries and areas.
- Your location comes from 620 built-in cities, a locator you type in, or the computer’s GPS if it has one.
- The clock, which FT8 needs within about a second, is corrected from the timing of the stations it hears.
The list can be sorted by distance with one click, which is a nice way to see how far your antenna is reaching.
Other additions
- Keyboard shortcuts, including typing a frequency on the number pad from anywhere
- Memory markers on the spectrum, and a UTC clock
- PSK decoding that starts part-way through a transmission
- RTTY that works out which way round mark and space are by itself
- A power-on “lamp test” that lights every light in the top bar for two seconds, like a car dashboard
The bug hunt
The most interesting part of this release was a bug that only showed on a MacBook. After powering off and on, the receiver would come back with only noise until you changed band. The diagnostics log showed the stick on exactly the right frequency, locked, delivering data at full rate, but with everything 36 dB weaker. The tuner’s gain had been left at its lowest.
The cause looks like timing. On power-off the tuner goes into standby with its amplifiers turned down. On power-on, the first register writes after it wakes are exactly those amplifier registers, and on a fast USB path some of them seem to get lost. Re-sending the gain a moment after start-up cures it. It later turned up on a Windows laptop too, once the start-up sequence got faster.
Along the way I sent six fixes to Jacobo Tarrío, the author of the webrtlsdr library OFFgrid-SDR is built on, and he has taken most of them upstream. That includes a better fix for another restart bug, where the tuner’s frequency rounding made the receiver drift a few hertz at every restart until it stopped following the tuning altogether.
self-test
As part of future releases I have added in an internal self test tool as a way to bug hunt before release.
Future releases should be as near to bug free as possible.
Ideal for testing before release.
The project, the single file and full release notes are on GitHub: https://github.com/diddy-boy/OFFgrid-SDR
diddy
