This was a bit of TTL teaching based on the 74LS TTL chips, that just went further than I ever expected! I concluded we could build a simple CPU that could be elegant and understandable! It will be on KickStarter before 20th October I hope.
It became the A5 minimal mini-computer! So named for its A5 paper size (210×148 mm) PCBs. It has a 24-bit data bus and a 24-bit address bus, 3MB of battery backed memory expandable beyond 6MB and it also has a wonderful RISC instruction set. https://a5computer.com/code/code.html
Its A5 PCBs stack and connect via a black 100 way connectors that form a backplane (See photo, left of PCB).
It currently stands just under 100 mm high and consists of 6 A5 PCBs The boards are;
Binary Operator Front Panel
Binary Operator Back Panel
Instruction Decoder
Address Registers
Arithmetic and Logic Unit
Core Memory
016 04000020 :ADDRESS 16#100010
017 04000020 018 04000020 .START
019 04000020 ;Experiment to move an immediate value in and out of A3 020 04000020 000000 000 0 11 100 000 010 011 MOV (PC++) DAR
021 04000021 001 100 110 011 001 100 110 011 :WORD 16#333333
022 04000022 000000 000 0 00 011 111 000 000 MOV DAR A3
023 04000023 000000 000 0 00 111 011 000 000 MOV A3 ADR
024 04000024 000000 000 0 00 000 000 000 000 NOP 025 04000025 026 04000025 ;Jump back to START
027 04000025 000000 000 0 11 100 000 010 011 MOV (PC++) DAR
028 04000026 000 100 000 000 000 000 010 000 :WORD .START
029 04000027 000000 000 0 00 011 100 000 000 MOV DAR PC
The three digit number on the extreme left is the line number in decimal.
The number following it is the memory address of the instruction in octal.
The binary numbers where they appear are the instruction stored at the address or the constant :WORD value.
They are broken into blocks of binary digits because each block is a part of the instruction and has a particular meaning;
23-18 ALU Function
17-15 3bit Test Condition if any use 000 for no test
14 Test for 0 or 1 use 0 for no test
13 Ax_CountOrHold
12 Ax_DownOrUp
11-9 Source Address
8-6 Destination Address
5-3 Source Data
2-0 Destination Data
Then follows the mnemonic and the parameters. (PC++) means the contents of the memory location pointed to by PC and then increment PC again after this instruction.
The PC is the Program Counter
A3 is an address register connected to the address bus
