Cold storage monitoring looks simple on a spec sheet. Temperature sensor, a radio, a dashboard. Then you talk to someone who runs a frozen warehouse at -30°C and realize the hard parts are everywhere: the cold, the condensation, the metal walls that eat RF for breakfast, and compliance paperwork that won't accept "the dashboard said it was fine" as evidence.
We've built monitoring hardware for pharmaceutical cold rooms, food distribution warehouses, and vaccine carriers. This post walks through how we approach a cold storage IoT product — the components, the firmware decisions, the logs that matter, and what shipping a working prototype actually involves.
When someone asks us for embedded product development services on a cold storage project, the deliverable isn't just firmware or a schematic. It's a unit that survives a real freezer, logs data an auditor will accept, and can be manufactured without a redesign. That means we own the whole stack — sensor selection, PCB layout, Zephyr firmware, cloud integration over MQTT, and the enclosure that keeps condensation off the board.
Why cold storage is a different problem
A standard office temperature sensor has an easy life. A cold storage unit has to survive:
- -40°C to +25°C swings during defrost cycles and door openings
- Condensation every time the compressor cycles and humidity spikes
- Metal racking and insulated panels that reflect 2.4 GHz signals
- Multi-year deployment with no one available to swap batteries on a ladder
That last one kills a lot of designs. A coin cell CR2032 works fine in a demo. In a freezer, its capacity drops to a fraction of rated value and the internal resistance climbs. We usually spec lithium thionyl chloride cells (like Tadiran TL-5903) or design for mains power with a supercapacitor backup.
Himanshu Dada
