Microcontroller Implementation using NuttX
A project log for Small Scale Experimental Machine (SSEM)
Emulating the Small Scale Experimental Machine (SSEM) aka the Manchester Baby, the first computer capable of executing a stored program.
nevynNevyn • 10/08/2026 at 18:16•0 Comments
By now we have the C++ code running on the desktop and the memory usage has been validated using valgrind.  The code should now be in a reasonable state to move to the memory constrained environment of microcontrollers.  The following platform is targeted here:
The initial port will replicate the desktop application by running the code through the serial console.  Additional hardware can be added later once the code has been proven to work.
Creating a NuttX Application
The process of creating a NuttX application is covered in the C++ Example documentation in the NuttX application documentation.
Building the NuttX application is a little more complex than the desktop application as the operating system needs to be built along with the application code.
Luckily this process is covered in some external guides I produced back in 2023:
Following these three guides generates should result in a basic ssem application deployed to the board.  Replacing the sample code in the Creating a NuttX application link above with the code in the GitHub repository linked from this project page should result in the SSEM simulator deployed to a PicoW board.
Testing the Application
The application can be tested by connecting a USB / Serial board to the PicoW.  The board starts with the NuttX shell (nsh) running by default.  Just open a terminal and connect to the USB / Serial board.  Connect using the parameters 115200,n,8,1 and press return twice.  If everything has deployed correctly the prompt nsh> should be displayed.
Enter the command help at the shell prompt and the ssem application should appear in the list of deployed applications.
Running the application shows output similar to the desktop and Python applications:
NuttShell (NSH) NuttX-10.4.0
nsh> ssem
                   00000000001111111111222222222233
                   01234567890123456789012345678901
   0: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
   1: 0x48020000 - 01001000000000100000000000000000 LDN 18           ; 16402
   2: 0xc8020000 - 11001000000000100000000000000000 LDN 19           ; 16403
   3: 0x28010000 - 00101000000000010000000000000000 SUB 20           ; 32788
   4: 0x00030000 - 00000000000000110000000000000000 CMP              ; 49152
   5: 0xa8040000 - 10101000000001000000000000000000 JPR 21           ; 8213
   6: 0x68010000 - 01101000000000010000000000000000 SUB 22           ; 32790
   7: 0x18060000 - 00011000000001100000000000000000 STO 24           ; 24600
   8: 0x68020000 - 01101000000000100000000000000000 LDN 22           ; 16406
   9: 0xe8010000 - 11101000000000010000000000000000 SUB 23           ; 32791
  10: 0x28060000 - 00101000000001100000000000000000 STO 20           ; 24596
  11: 0x28020000 - 00101000000000100000000000000000 LDN 20           ; 16404
  12: 0x68060000 - 01101000000001100000000000000000 STO 22           ; 24598
  13: 0x18020000 - 00011000000000100000000000000000 LDN 24           ; 16408
  14: 0x00030000 - 00000000000000110000000000000000 CMP              ; 49152
  15: 0x98000000 - 10011000000000000000000000000000 JMP 25           ; 25
  16: 0x48000000 - 01001000000000000000000000000000 JMP 18           ; 18
  17: 0x00070000 - 00000000000001110000000000000000 HALT             ; 57344
  18: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
  19: 0xc43fffff - 11000100001111111111111111111111 HALT             ; -989
  20: 0x3bc00000 - 00111011110000000000000000000000 JMP 28           ; 988
  21: 0xbfffffff - 10111111111111111111111111111111 HALT             ; -3
  22: 0x243fffff - 00100100001111111111111111111111 HALT             ; -988
  23: 0x80000000 - 10000000000000000000000000000000 JMP 1            ; 1
  24: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
  25: 0x08000000 - 00001000000000000000000000000000 JMP 16           ; 16
  26: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
  27: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
  28: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
  29: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
  30: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
  31: 0x00000000 - 00000000000000000000000000000000 JMP 0            ; 0
Program execution complete.
  20: 0x54000000 - 01010100000000000000000000000000 JMP 10           ; 42
  22: 0x6bffffff - 01101011111111111111111111111111 HALT             ; -42
Executed 21387 instructions in 30000000 nanoseconds
