Lessons, and rev2
A project log for RadioStreamer: TV Fiber/DR LYD for Vintage Beolab
ESP32-S3 decodes TV optical S/PDIF in software with the RMT peripheral, streams Danish DR radio over Ethernet, and feeds Beolab 4000s.
carsten-bgh-poulsenCarsten Bøgh Poulsen • 11 hours ago•0 Comments
Some things that cost me time and might save you some:
Rev2 of the PCB is drawn: a separate MIC5205 LDO with a ferrite bead for the DAC's analog supply, the DAC's soft-mute pin on GPIO38 with a pull-down so it stays silent through boot, a TSOP38438 IR receiver on GPIO4 so the box gets a dedicated remote of its own, the RCA footprints corrected, and the OLED reset line dropped (the 4-pin module doesn't have one).
Next up is the real test: the living room. After that, rev2 boards, a cleaner DAC supply, and a remote that isn't the TV's.
